Author Topic: Brake discs/pads  (Read 7044 times)
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Brake discs/pads
« Reply #30 on: 06 April 2013, 15:55 »
Likewise,  ive always managed to reuse mine on the past three mk3's.
Offline Foreveryoungaus16v
« Reply #31 on: 06 April 2013, 16:54 »
Mintex sell rear discs with or without the abs rings :smiley:
163 BHP (TSR POWER RUN)
Offline GOLF-MK3-GTI
« Reply #32 on: 11 April 2013, 17:29 »
I'm buying these. But i'm stuck on which pads will fit mine;
http://www.ebay.co.uk/itm/Golf-mk3-Gti-Front-Rear-Drilled-Brake-Discs-Pads-96-97-/300474777007?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Car+Make%3AVW%7CModel%3AGolf%7CPlat_Gen%3AMK+III&hash=item45f5b13daf#ht_0wt_0
Look halfway through description, it shows pics of pads. Which one do i choose lol
Help  :cry:
« Reply #33 on: 11 April 2013, 17:56 »
I would avoid drilled they crack.  Grooved better choice.  Just buy basic mintex front and rear discs and rear
pads with more expensive front pads like Mintex M1144.  Thats the advice I been given.  Your car dont
produce loads of power.
http://www.ebay.co.uk/itm/400371233195?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
« Reply #34 on: 11 April 2013, 19:25 »
It says on the listing you have a choice on which type you like. Not sure what to get, prob get grooved only or sumat daft like that.
Still looking around yet  :wink:
Offline sharki786
  • GOT BOOST??
« Reply #35 on: 11 April 2013, 19:53 »
I got grooved front and rear discs from mtech for 104. I also got yellow stuff pads as i mentioned previously. I have fitted them too. I also got new rear bearings (fag) from central auto supplies for 10 each side. They come with the bearing grease and was a full kit.
Also you should be able to reuse the abs ring (i sprayed plenty of wd40 and gently prised it off and fitted then i aint had a issue with abs either. Why do you want to replace the abd sensor? If its playing up then fair if its not then dont waste your money mate.
*****MK3 Anniversary*****
*****MK4 GTI T*****
« Reply #36 on: 11 April 2013, 20:01 »
Sharki abs is fine, so I won't get sensors then lol. What do you mean by fag?
Offline sharki786
  • GOT BOOST??
« Reply #37 on: 11 April 2013, 21:21 »
Fag is a make not f*g**t lolsss :grin: like bosch luk sachs vw all that balls. You get my drift mate? Lol
*****MK4 GTI T*****
« Reply #38 on: 11 April 2013, 21:32 »
:embarrassed:  :grin:
