Author Topic: Rewinding rear caliper piston....  (Read 3830 times)
Offline gm8
Re: Rewinding rear caliper piston....
« Reply #20 on: 06 April 2013, 17:07 »
any luck today then m8 ?
Offline hardmonkeys
« Reply #21 on: 06 April 2013, 17:18 »
Bought a new caliper today, also a new brake pipe, the 11mm union was a nightmare to get off, so ended up bending the bracket, got it off tho, just got to bend it back, then put all back together, then bleed the system... :undecided:
Hopefully will have all day tomoz on it. Hoping get it back on its wheels tomorrow!
Fingers crossed  :rolleyes:
'05 VW Golf Mk V GT TDI Laser Blue
'98 VW Golf Mk IV GTi Black
'97 VW Golf Mk III GTi
'58 VW Golf Mk V GT Sport TDI Steel Grey
'10 Audi A4 B8 SE Multitronic
'00 VW Golf Mk III.V Cabrio
'12 Audi A5 S Line Black Edition
'03 VW Golf V6 4motion
MK3.5 Cabrio 2.0 8v Automatic to 2.0 16v Manual Conversion Project
http://www.golfgtiforum.co.uk/index.php?topic=272728.
www.dorsetautorestore.co.uk
Offline gm8
« Reply #22 on: 06 April 2013, 18:33 »
ah well,  should be back on the road soon then  :smiley:
Offline hardmonkeys
« Reply #23 on: 06 April 2013, 19:34 »
Does this look right?? The union won't go in any more!!
Offline hardmonkeys
« Reply #24 on: 06 April 2013, 19:46 »
The new union has more thread than the old...should be ok right??
Offline gm8
« Reply #25 on: 06 April 2013, 20:26 »
you will know as soon as you start to bleed , but think it looks ok
Offline hardmonkeys
« Reply #26 on: 14 April 2013, 11:54 »
This wasn't ok...pissed brake fluid out when attempting to bleed the pipe....the new union had 4 or so extra threads..so although the union was tight, the pipe wasn't tight up against the other side...that's what you get for buying non genuine parts..so back to VW for a genuine part now...tried to,save money..ended up costing more now :-/ oh well you live and learn
Offline gm8
« Reply #27 on: 14 April 2013, 13:13 »
did you get the pagid ones from ECP ?  I have them on mine with no probs ?
Offline hardmonkeys
« Reply #28 on: 14 April 2013, 13:30 »
Yep I did...I did notice the union tho didn't I. It's ok, I'll see how the VW one does..can't see why it shouldn't
Offline pickles
  • Next!!!
« Reply #29 on: 14 April 2013, 15:40 »
rear brakes are a nightmare m8, hope you get it sorted
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
