Author Topic: Rewinding rear caliper piston....  (Read 3829 times)
Offline beppe2672
Re: Rewinding rear caliper piston....
« Reply #10 on: 05 April 2013, 19:35 »
Take a trip to your local dealers and have a chat with the guy at the parts desk! If you're savvy with a spanner, a refurb kit for your rear calipers is around 30 quid from big red.
1999 1.8t AGU, KNN Panel filter, Smoothed air box, Custom CAI, Forge 007 dv, REVO stage 1, 3" eBay TBE. Audi TT quickrack.
To come - A DIY hybrid K03 and a whole lot of supporting mods!
Offline Tezmax
« Reply #11 on: 05 April 2013, 20:54 »
As for the brake pipe, take it off at next connection and keep the shape as it comes off.
I took mine somewhere local and they made me a new one while i waited.
1.8t Aum. forge 007p. 17" bbs. R-tech stage 1 map.205/235. catch can.
Offline gm8
« Reply #12 on: 05 April 2013, 21:01 »
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf_1.8_2000/p/car-parts/brakes/brake-hydraulics/brake-hose-and-brake-pipe/?135441118&1&0e866f033911c31edfbd43e63282b5d522798ba1&000030
You need that (or the other side)
Easy job but you will need to bleed the brakes.
PS you did have the fluid res cap off yeah ??
And you can buy a new seal kit on ebay for £10 ( i have just done all my rear ones)
« Last Edit: 05 April 2013, 21:02 by gm8 »
Offline hardmonkeys
« Reply #13 on: 05 April 2013, 21:15 »
Sound!!!!
That's not as bad as I thought! I thought it would be from master cylinder back...how does connect...
'05 VW Golf Mk V GT TDI Laser Blue
'98 VW Golf Mk IV GTi Black
'97 VW Golf Mk III GTi
'58 VW Golf Mk V GT Sport TDI Steel Grey
'10 Audi A4 B8 SE Multitronic
'00 VW Golf Mk III.V Cabrio
'12 Audi A5 S Line Black Edition
'03 VW Golf V6 4motion
MK3.5 Cabrio 2.0 8v Automatic to 2.0 16v Manual Conversion Project
http://www.golfgtiforum.co.uk/index.php?topic=272728.
www.dorsetautorestore.co.uk
Offline gm8
« Reply #14 on: 05 April 2013, 21:19 »
1 x 11mm bold just under the rear bear , and then a 13 mm banjo fitting on the caliper. Easy to do m8. follow the hard brake line to the bolt , but you will see when you get the part. douse the old bolts in wd40 or such like before removal, and use a proper brake spanner if ya have one
Offline hardmonkeys
« Reply #15 on: 05 April 2013, 21:27 »
Brilliant! Not got a brake spanner..will a normal one do the job??
Offline gm8
« Reply #16 on: 06 April 2013, 06:53 »
yeah, just more prone to rounding off, as the line is being replaced anyway you can chop it and use a socket.
Offline hardmonkeys
« Reply #17 on: 06 April 2013, 06:56 »
Never bled brakes on my own...is it difficult? What about the ABS..does This make it more difficult?
Offline gm8
« Reply #18 on: 06 April 2013, 07:15 »
as long as the system does not run dry (it shouldnt) you shouldnt need to worry about ABS pump. get a one man bleeding kit (eezibleed is good , under a score) follow this order : Rear Nearside,Rear offside,Front Nearside,Front Offside, master cyl nipple 1 (closest to headlights, master cyl nipple 2.
Bleeding can be a bit of a pain tho . Get about a litre of fluid at least.
http://www.myturbodiesel.com/1000q/a4/brake-clutch-fluid-change.htm
lots of guides about.
Offline hardmonkeys
« Reply #19 on: 06 April 2013, 07:22 »
Thanks mate! You're a diamond!
