Author Topic: problems cold starting  (Read 1421 times)
Offline stefanedge
« on: 05 April 2013, 14:36 »
Got a mk3 1.9d. it has problems cold starting which has been recently getting worse. in the morning it usually takes 2-3 attempts to get it started. i turn on the glow plugs twice till i turn it over. and the same when i finish work. yesterday it didn't start and had to bump start it.
it has a faulty thermostat (always open) and only water in the cooling system.
anyone got any ideas to what the cause could be? I've been told may be glow plugs. bought a new thermostat today and that will be getting fitted once I've flushed the system.
Any help would be much appreciated. cheers.
Offline itavaltalainen
Re: problems cold starting
« Reply #1 on: 05 April 2013, 18:01 »
fix thermostat, measure glow plugs with multimeter individually (should be 1-2 Ohms or thereabouts for each plug).
check fault code, maybe something in there.....
Offline javalin
« Reply #2 on: 05 April 2013, 18:05 »
yeah +1 for the glow plugs.  New set required I think!
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
