Author Topic: rear electric window...munched??  (Read 754 times)
Offline hardmonkeys
« on: 01 April 2013, 15:09 »
hi all,
attempting to fix my rear electric window as it didnt moved, despite the motor moving..and this is what i was face with...
assuming it cant be repaired...so is it a new motor?
is it part of the locking module aswell(fault code with that too..)
warren
'05 VW Golf Mk V GT TDI Laser Blue
'98 VW Golf Mk IV GTi Black
'97 VW Golf Mk III GTi
'58 VW Golf Mk V GT Sport TDI Steel Grey
'10 Audi A4 B8 SE Multitronic
'00 VW Golf Mk III.V Cabrio
'12 Audi A5 S Line Black Edition
'03 VW Golf V6 4motion
MK3.5 Cabrio 2.0 8v Automatic to 2.0 16v Manual Conversion Project
http://www.golfgtiforum.co.uk/index.php?topic=272728.
www.dorsetautorestore.co.uk
Offline navmk4gti
Re: rear electric window...munched??
« Reply #1 on: 01 April 2013, 15:56 »
Had this happen twice on my gti both rear doors :lipsrsealed:
You need new window regulator your motor should be ok. Get one with the metal clips :wink:
Offline hardmonkeys
« Reply #2 on: 01 April 2013, 16:01 »
sweet..
thanks for that :-)
under the door card is the metal plate ..with 7 or so 10mm bolts, after ive taken the bolts out..i assume the plate is then held with sealant..will it come off with a massive tug(easy now..gutter lovers lol)?
Offline barrym381
« Reply #3 on: 01 April 2013, 16:07 »
just make sure you seal it back up right as they are known to leak  :smiley:
Offline navmk4gti
« Reply #4 on: 01 April 2013, 16:11 »
Yh but it has some sealent on it. To be fair i did not reseal mine :lipsrsealed: but then you have risk of leak as said :grin:
The regulator is screwed on the plate. Bit of a b!tch just change regulator cable so best just change whole regulator :wink:
Offline hardmonkeys
« Reply #5 on: 01 April 2013, 18:20 »
Excellent! I have fault code coming up with The door module anyway, so will just wait til I got the bits to to the lot
Thanks
