Author Topic: front seat removal  (Read 1719 times)
Offline hardmonkeys
front seat removal
« on: 01 April 2013, 12:46 »
removing the drivers seat to have a look at the airbag connectors, and its a different mech to the passenger...first of all it has 2 13mm bolts, instead of torx bolts...and second it doesnt come off the runners as easy...
does this look right...
as most know, i bought the car with no history...and the vagcom fault code has come up with
Address 15     -------------------------------------------------------
   Controller: 1J0 909 609
   Component:  A AIRBAG VW3 SG   0002
   Coding: 00065
   Shop #: WSC 00028
3 Faults Found:
01280 - Airbag: Passenger Side: Disabled
            35-00 - -
01217 - Side Airbag Igniter: Driver Side (N199)
            32-10 - Resistance too High - Intermittent
00532 - Supply Voltage B+
            07-10 - Signal to Low - Intermittent
im just hoping the previous owner hasnt messed with things and bodged this seat with anything to get it bolted back in
any ideas?
thanks
« Last Edit: 01 April 2013, 12:56 by hardmonkeys »
'05 VW Golf Mk V GT TDI Laser Blue
'98 VW Golf Mk IV GTi Black
'97 VW Golf Mk III GTi
'58 VW Golf Mk V GT Sport TDI Steel Grey
'10 Audi A4 B8 SE Multitronic
'00 VW Golf Mk III.V Cabrio
'12 Audi A5 S Line Black Edition
'03 VW Golf V6 4motion
MK3.5 Cabrio 2.0 8v Automatic to 2.0 16v Manual Conversion Project
http://www.golfgtiforum.co.uk/index.php?topic=272728.
www.dorsetautorestore.co.uk
Offline SI74
Re: front seat removal
« Reply #1 on: 01 April 2013, 14:43 »
same as mines.
Offline hardmonkeys
« Reply #2 on: 01 April 2013, 15:04 »
brilliant...least I know
thanks
« Last Edit: 01 April 2013, 15:10 by hardmonkeys »
Offline Rhyso
« Reply #3 on: 01 April 2013, 15:34 »
The seats should be bolted on and not with torx bolts  :undecided:
Offline hardmonkeys
« Reply #4 on: 01 April 2013, 15:44 »
Hmmm...this is what i had on the passenger side
the same as Mr Haynes
