Author Topic: Why Oh Why Oh Why ?  (Read 6218 times)
Offline hardmonkeys
Re: Why Oh Why Oh Why ?
« Reply #10 on: 30 March 2013, 15:24 »
It was either a high speed bump, your car is too lowered...or you were going some speed to hit a speedbump And damage the sump, most damage I've had over a speedbump is scrape something underneath.
You could attempt to take the council to court over it, after all if its too high, it's their fault...but other people would of had the same damage or more...
If it were me..I'd slow down!!
'05 VW Golf Mk V GT TDI Laser Blue
'98 VW Golf Mk IV GTi Black
'97 VW Golf Mk III GTi
'58 VW Golf Mk V GT Sport TDI Steel Grey
'10 Audi A4 B8 SE Multitronic
'00 VW Golf Mk III.V Cabrio
'12 Audi A5 S Line Black Edition
'03 VW Golf V6 4motion
MK3.5 Cabrio 2.0 8v Automatic to 2.0 16v Manual Conversion Project
http://www.golfgtiforum.co.uk/index.php?topic=272728.
www.dorsetautorestore.co.uk
Offline hardmonkeys
« Reply #11 on: 30 March 2013, 15:26 »
Where do they usually crack to because it's leaking from the back of the sump
The easy answer is...they don't normally crack! Only if they are 'walloped' against a hard surface...
Offline dom
  • Back in a Mk4
« Reply #12 on: 30 March 2013, 15:39 »
I'd like to see anyone try and win that one :lipsrsealed:
It does indeed sound like you've cracked your sump, to be honest they don't take a lot to break so if it came into contact with a speed bump I'm not surprised.
You'll need a new sump and sealant, it will also be worth changing the pickup pipe whilst your there
Offline hardmonkeys
« Reply #13 on: 30 March 2013, 15:51 »
Good excuse for an decent oil change too...think of the positives welshdean :-)
Online barrym381
« Reply #14 on: 30 March 2013, 15:55 »
he wont have any left to change  :smug:
Offline hardmonkeys
« Reply #15 on: 30 March 2013, 16:01 »
Tru...
Offline Chris#101
« Reply #16 on: 30 March 2013, 16:03 »
You've probably knocked the lead off the Sensor at the bottom of the sump. I did the same a few weeks ago which brought up low oil pressure. Leak is probably a cracked sump!
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline welshdean
« Reply #17 on: 30 March 2013, 16:15 »
Is there anything I can use to possibly put into the oil to seal the sump atall or some way to seal this mysterious leak.
I was thinking along the lines of radweld
Offline Chris#101
« Reply #18 on: 30 March 2013, 16:18 »
I guess you could use evo stick liquid.metal but the.sump would still have.to come.off and wouldn't.be a guaranteed.fix
Offline hardmonkeys
« Reply #19 on: 30 March 2013, 16:19 »
Radweld....really lol??
You need a new sump mate..radweld blocks SMALL water leaks...
Drain the remaining oil..remove the sump..clean it up, see if you see a crack, if not..fill with water..see if/where it leaks..if its confirmed a crack...you need a new sump
