Author Topic: bottom heat shield on cat rattling-solved-removed  (Read 3577 times)
Offline Jasikasisback
« on: 29 March 2013, 23:48 »
the lower heat shield on the cat is rattling. the front of it has seperated and is hanging down slightly. this may be dangerous if it catches and the force sends it into the cat??
i was wondering if i can just use a coathanger to tie it to the exhaust. i know the cats get quite hot and it might just come apart.would it pass the mot without the heat shield and if removed would the cat heat up enough to pass emissions testing/ function properly?
i will not be welding anything on this car if i can help it until after mot(if it passes) in july.
« Last Edit: 01 April 2013, 03:20 by Jasikasisback »
Gavv8
Re: bottom heat shield on cat rattling
« Reply #1 on: 30 March 2013, 07:40 »
Its not heavy enough to damage the cat and i shouldn't think its an mot failure unless the whole thing is detached, i use very small nyloc nuts to secure the heat shields back up on mine as it seems to work and its a bit tidyer than bits of old wire.
« Last Edit: 30 March 2013, 14:55 by Gavv8 »
VW BUSH
« Reply #2 on: 30 March 2013, 10:48 »
Big juby clip or metal cable ties, 5 mins and sorted.
« Reply #3 on: 30 March 2013, 11:12 »
will try to find a big jubilee clip and give it a go...
VW BUSH
« Reply #4 on: 30 March 2013, 14:30 »
You can join two together if stuck
« Reply #5 on: 01 April 2013, 03:19 »
decided to just take it off as was hanging by a thread.
Gavv8
Re: bottom heat shield on cat rattling-solved-removed
« Reply #6 on: 01 April 2013, 07:04 »
I don't think thats a very good idea,the cat gets pretty hot.. :undecided:
Offline Dogbot
« Reply #7 on: 01 April 2013, 09:24 »
Removing it is fine....
Gavv8
« Reply #8 on: 01 April 2013, 13:33 »
As long as you don't mind setting fire to your carpets.
Offline DCmk3
« Reply #9 on: 01 April 2013, 13:39 »
Does it really create that much heat?  :huh:
2014 Mk7 GTI - Littco L500
