The garage
dizi question
Topic: dizi question (Read 1863 times)
yougy
dizi question
29 March 2013, 13:27 »
iv a golf mk3, if i twist the rotor arm one way should it spring back by its self, does it make any differance if it dont
thanks dave
thats fooked it
dixie180
Here all the time
Mk3 8v Gti,Mystic Blue the best colour.
Re: dizi question
29 March 2013, 13:29 »
Rotar arm only fits one way so why should you want to twist it round.
yougy
Re: dizi question
29 March 2013, 13:33 »
wot i mean is when its fitted, if you twist the rotor arm lightly around should it spring back by its self
dave
thats fooked it
dixie180
Here all the time
Re: dizi question
29 March 2013, 13:45 »
I don't think the rotar arm should spring back as its connected to a series of small cogs at the bottom of the distributor shaft.You might get a bit of play in the rotor arm as it sits on the top of the shaft but not much.
analogue_rogue
Guest
Re: dizi question
09 April 2013, 14:01 »
it shouldn't have any play in it. otherwise the timing wouldn't be stable while changing rpm (gear changes etc)
danny_p
Forum addict
Re: dizi question
09 April 2013, 22:25 »
they are springy, your manualy pulling the advance mechanisum around.
pulling the rotor arm right round dosent do the dizzy much good sometimes tho
all the VW's have gone bar 1.
analogue_rogue
Guest
Re: dizi question
Reply #6 on:
10 April 2013, 08:38 »
didnt think mk3 had vacuum advance.. thought they were all hall effect so it wont have a manual advance?
The garage
dizi question
