Author Topic: MFA Thingy  (Read 897 times)
Offline Logie
MFA Thingy
« on: 01 August 2005, 10:02 »
Sures its the MFA? On the right stick tells you the MPG, MPH, Time Oil temp etc etc
  Well, had moonsoon rain yestaday and noticed that themiles done was 1576 and time driving 64:33 hours :O and the MPG was stuck. All that worked was the time, Oil temp and outside temp
 This a common fault? Car is 18 years old, but if theres a way to prevent it by putting a bag over something be greatfull :)
Offline kniterider
  • had most, sold most and often buy more!
Re: MFA Thingy
« Reply #1 on: 01 August 2005, 10:11 »
there not normally effected by rain!!! lol, disconnect your battery and leave it for 5/10 mins then reconnect and have a go.......
if you can still toggle between the modes then you stalk is still ok, if after reconnecting the battery its still the same you might need a new/secondhand set of clocks as they do go wrong!! try the battery thing 1st though!!
 :cool:
Gaz
Offline Logie
Re: MFA Thingy
« Reply #2 on: 01 August 2005, 10:39 »
It back to normall now. But, the ECU is under the bonnet top left yea? So, when jet washing my car im thinking its gone through the bonnet grills just under the Sil, thinking that could of done it.
  It was bugged for about 6. Then just came back to normall! It was fine till i Jetwashed the car and then drove in a moonsoon
