Author Topic: Fitting mk3 fog loom  (Read 1830 times)
Offline dan_thevdub_man
« on: 25 March 2013, 22:45 »
Anyone able send me a link or talk me through how to fit the loom for the fogs on mk3 8vgti plz
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Fitting mk3 fog loom
« Reply #1 on: 25 March 2013, 23:59 »
I'm assuming you're swapping the headlight loom section that runs along the top of the radiator / slam panel? It's quiet literally a case of twisting the big round connector block out and unclipping the wiring from it's metal retainers.
What are you stuck on exactly?
Offline sharki786
  • GOT BOOST??
« Reply #2 on: 26 March 2013, 09:03 »
Didnt all the gtis have fogs on them? It not hard.
Main 2 things you need is the front and rear fog headlight switch and loom. As said above. If you look inside of your engine bay by the rad there will be a big round block with wires. You just twist the plug and it co.e apart then you disconnect all the llugs that goes to the headlights indicators and horn and i think outside air temp. Fitti g is reversal and you will have 2 extra plugs (fog lights) after fitting check everything.
*****MK3 Anniversary*****
*****MK4 GTI T*****
« Reply #3 on: 26 March 2013, 10:08 »
No,  not all GTI's came equipped with front fog lights.  IIRC it was an optional extra on pre 96 mk3's.
Offline itavaltalainen
« Reply #4 on: 26 March 2013, 10:24 »
you don't need the fog wiring loom.... can make it yourself.
all you need is a spade connector, wires, the two connectors for the fogs and of course the light switch.
pin 5 on the round connector is for fogs, gnd is not difficult to come by .... just go straight for battery terminal
« Reply #5 on: 26 March 2013, 13:59 »
This said, I've got a spare loom in the shed if you're interested?  :whistle:
« Reply #6 on: 26 March 2013, 14:04 »
all done lads thnks for the help
