Author Topic: B1 oxygen lambda sensor no signal  (Read 1078 times)
Offline welshdean
« on: 24 March 2013, 19:25 »
Hi all,
I've just had the car checked with vcds and it showing a fault for B1 oxygen lambda sensor ( no signal... Or something similar ).
I'm not sure what this is but the sensor is only one week old and it was new when replaced .
Can anybody shed some light on what this could mean please its a 2.0 gti
Offline davemk4
Re: B1 oxygen lambda sensor no signal
« Reply #1 on: 24 March 2013, 20:25 »
was it a decent brand fitted? or a universal type fitted?
ive had on my gti turbo resistance low etc as i have a decat fitted so that explains mine
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline welshdean
« Reply #2 on: 24 March 2013, 20:52 »
It is a cheap one mate
Offline mar_k
« Reply #3 on: 24 March 2013, 21:05 »
1.8t's are very sensitive to the type of sensors used.
Genuine seems to be the only way.
Offline welshdean
« Reply #4 on: 24 March 2013, 22:21 »
Could my problem be the sensor itself is sh!t or could it be something else
Offline davemk4
« Reply #5 on: 25 March 2013, 07:04 »
Cheap o2 sensors are crap across board. Either genuine or bosch id say.
Offline Nino
« Reply #6 on: 25 March 2013, 12:18 »
I did tell him  :rolleyes:
Current - MK6 GTi Edition 35
