Author Topic: poor idle getting worried  (Read 2552 times)
Offline dan_thevdub_man
« on: 24 March 2013, 18:51 »
i knw i have posted this question many a time but im starting to get wrried now...
iv replaced ht leads spark plugs etc and dizzy
air filer replaced and maf cleaned with contact cleaner, i need to clean the throttle body but...
regardless of this when i start the car on cold i will not idle and if it does it hovers around 800rpm then dies, i have to keep throttle down for about 3 mins at bout 1000rpm then usually it idles perfect at around 650-800rpm. is this common and what are the usual fixes..or could this be something more sinister. iv seen someone mentioning ecu and various differant relays
its the 8v 97 agg
thanks guys please help
Offline tweed
Re: poor idle getting worried
« Reply #1 on: 24 March 2013, 19:29 »
Ecu relay #30
Fuel pump relay #167
« Reply #2 on: 24 March 2013, 19:46 »
am i being a f**ktard or is there a specific relay i need or do these work http://www.eurocarparts.com/car-regulators-relays-and-solenoids
Offline boneybradley
  • Back in a Mk3...
« Reply #3 on: 24 March 2013, 20:04 »
you need the specific one's.... try your dealer as last time I got one it was same price as those listed on ecp
Offline dixie180
  • Mk3 8v Gti,Mystic Blue the best colour.
« Reply #4 on: 24 March 2013, 20:23 »
Got both 30 and 167 relay from dealers and cost £26 for the pair including VAT.
« Reply #5 on: 24 March 2013, 20:32 »
official vw dealer?
Offline dixie180
« Reply #6 on: 24 March 2013, 20:33 »
Yep official VW dealers.
« Reply #7 on: 24 March 2013, 20:37 »
ok thanks mate iv just emailed them
are they easy to fit/replace
Offline dixie180
« Reply #8 on: 24 March 2013, 20:41 »
Yeah a doddle.They plug in the fuse box which is located under the right hand side of the dash.There should be a cover over the fuse box with 2 green clips either side of the cover.Pull that cover off and you should see the fuse box.Either side of the fuse box are 2 white clips that push up allowing you to drop the fuse box out.Sounds difficult but it aint m8.
« Reply #9 on: 24 March 2013, 20:42 »
ok cheers mate. before i buy the relays tho is there a check i can do on them to make sure they arent working
