Author Topic: Diagnostic on the mk4 today  (Read 5495 times)
Offline hardmonkeys
« on: 24 March 2013, 16:55 »
Hello all, took the  GTi over to Lymington today to meet Khare who used his lead to do a ful diagnostic on it, first things 1st tho, I've not met a nicer, more helpful bloke in my time using forums, so thanks again to Khare, you are a knowledgeable lad!!
So...here are the results of the scan...
VAG-COM Version: Release  311.2-N
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01     -------------------------------------------------------
   Controller: 06A 906 018 CL
   Component: 1,8l R4/5V  MOTR HS V02
   Coding: 04000
   Shop #: WSC 00028
No fault code found.
Address 03     -------------------------------------------------------
   Controller: 1J0 907 379  H
   Component: ABS/EDS 20 IE CAN  0001
   Coding: 13504
   Shop #: WSC 00028
Address 15     -------------------------------------------------------
   Controller: 1J0 909 609
   Component:  A AIRBAG VW3 SG   0002
   Coding: 00065
   Shop #: WSC 00028
3 Faults Found:
01280 - Airbag: Passenger Side: Disabled
            35-00 - -
01217 - Side Airbag Igniter: Driver Side (N199)
            32-10 - Resistance too High - Intermittent
00532 - Supply Voltage B+
            07-10 - Signal to Low - Intermittent
Address 17     -------------------------------------------------------
   Controller: 1J0 919 930 B
   Component: A4-KOMBIINSTR. VDO V61
   Coding: 04442
   Shop #: WSC 00028
   IMMO-IDENTNR: VWZ7Z0W0678635
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
            30-10 - Open or Short to B+ - Intermittent
Address 46     -------------------------------------------------------
   Controller: 1J0 959 799 J
   Component: 16 Zentral-SG Komf.0002
   Coding: 04096
   Shop #: WSC 00028
4 Faults Found:
00928 - Locking Module for Central Locking: Front Driver Side (F220)
            27-10 - Implausible Signal - Intermittent
00929 - Locking Module for Central Locking: Front Passenger Side (F221)
00935 - Electric Window Motor: Rear Right (V27)
            62-00 - No or Incorrect Adjustment
00931 - Locking Module for Central Locking: Rear Right (F223)
End   -------------------------------------------------------
Not as bad as I thought...anyone care to explain in English this to me lol..
The airbag light, which was my main concern, as its the only warning light on the dash, it say its deactivated, how do I reactivate this? Can I do it, if I bought my own lead, or it is a VW thing again...also, the side airbag igniter, how to sort the resistance being to high?
Also the immo??(what's this) says coolant temp sensor open or short to b+ what's this??
Thanks in advance..
Warren
'05 VW Golf Mk V GT TDI Laser Blue
'98 VW Golf Mk IV GTi Black
'97 VW Golf Mk III GTi
'58 VW Golf Mk V GT Sport TDI Steel Grey
'10 Audi A4 B8 SE Multitronic
'00 VW Golf Mk III.V Cabrio
'12 Audi A5 S Line Black Edition
'03 VW Golf V6 4motion
MK3.5 Cabrio 2.0 8v Automatic to 2.0 16v Manual Conversion Project
http://www.golfgtiforum.co.uk/index.php?topic=272728.
www.dorsetautorestore.co.uk
Offline Rhyso
Re: Diagnostic on the mk4 today
« Reply #1 on: 24 March 2013, 17:01 »
Airbag needs to be switched back on via VAGCOM though you will most likely need a genuine lead to do this....
Side ignitor could be a dodgy loom under the seat itself; think they are about £20
Replace your coolant temperature sensor
Door locking modules; are they playing up? Do the locks sometimes pop back up when locking or unlocking the car??
Was Khare able to clear any of the codes?? Did any come straight back?
Offline hardmonkeys
« Reply #2 on: 24 March 2013, 17:16 »
Hi mate, one engine fault came up, and he cleared it, and it never came back up...
This lot we cleared, and it came back again, so it's a definite.
Will do a search on coolant temp sensor replacement...is it easy todo?
Offline Rhyso
« Reply #3 on: 24 March 2013, 17:23 »
What was the engine fault?  :huh:
Coolant sensor is a 5 minute job; just make sure the old O-ring comes out with the sensor as they tend to get stuck so you fit the new sensor with a new o-ring and your coolant pisses all over the floor......
Do it while the engine is cold by the way  :wink:
Offline hardmonkeys
« Reply #4 on: 24 March 2013, 17:28 »
Ohh, I really can't remember, voltage too low or something, I didn't get the fault code. I have ordered my own lead anyway,so I wil do a check when I get it, see if its back after the journey home, (60miles).
Offline hardmonkeys
« Reply #5 on: 24 March 2013, 18:49 »
Quick question...my temp gauge goes up to 90/midway whilst stationary, soon as I start driving it drops steadily down to cold, heaters stay warm, Figured the thermostat needs changing, would this affect the coolant temp sensor(CTS)...if I replaced the stat, could this help the coolant sensor fault correct itself?
Or is it a case of replace CTS and the stat would in effect work again ...OR...
replace both anyway....
Thanks
Offline barrym381
« Reply #6 on: 24 March 2013, 18:58 »
Thanks
Replace both mate  :smiley:
Offline hardmonkeys
« Reply #7 on: 24 March 2013, 19:01 »
Ok mate, suppose they are inexpensive enough
Offline dom
  • Back in a Mk4
« Reply #8 on: 25 March 2013, 17:53 »
Make sure you buy genuine parts though, I replaced my thermostat with one from Euro Car Parts and it lasted 2 weeks!
Offline hardmonkeys
« Reply #9 on: 25 March 2013, 18:13 »
Ahhh...I bought one from there today...will try it..see how it goes..if it last a few weeks...I won't buy anything from them again..
Thanks tho pal, it's always good to,hear other people's advice and experiences on companies
Warren
