Author Topic: Diagnostic on the mk4 today  (Read 5508 times)
Offline hardmonkeys
Re: Diagnostic on the mk4 today
« Reply #20 on: 28 March 2013, 19:21 »
That's interesting to know, how do I find out the range of parameters of a certain thing?
'05 VW Golf Mk V GT TDI Laser Blue
'98 VW Golf Mk IV GTi Black
'97 VW Golf Mk III GTi
'58 VW Golf Mk V GT Sport TDI Steel Grey
'10 Audi A4 B8 SE Multitronic
'00 VW Golf Mk III.V Cabrio
'12 Audi A5 S Line Black Edition
'03 VW Golf V6 4motion
MK3.5 Cabrio 2.0 8v Automatic to 2.0 16v Manual Conversion Project
http://www.golfgtiforum.co.uk/index.php?topic=272728.
www.dorsetautorestore.co.uk
Offline hardmonkeys
« Reply #21 on: 01 April 2013, 13:42 »
done two tests today..
VAG-COM Version: Release  311.2-N
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01     -------------------------------------------------------
   Controller: 06A 906 018 CL
   Component: 1,8l R4/5V  MOTR HS V02
   Coding: 04000
   Shop #: WSC 00028
1 Fault Found:
18010 - Power Supply Terminal 30: Voltage too Low
            P1602 - 35-00 - -
Readiness: N/A
Address 03     -------------------------------------------------------
   Controller: 1J0 907 379  H
   Component: ABS/EDS 20 IE CAN  0001
   Coding: 13504
   Shop #: WSC 00028
No fault code found.
Address 15     -------------------------------------------------------
   Controller: 1J0 909 609
   Component:  A AIRBAG VW3 SG   0002
   Coding: 00065
   Shop #: WSC 00028
3 Faults Found:
01280 - Airbag: Passenger Side: Disabled
            35-00 - -
01217 - Side Airbag Igniter: Driver Side (N199)
            32-10 - Resistance too High - Intermittent
00532 - Supply Voltage B+
            07-10 - Signal to Low - Intermittent
Address 17     -------------------------------------------------------
   Controller: 1J0 919 930 B
   Component: A4-KOMBIINSTR. VDO V61
   Coding: 04442
   Shop #: WSC 00028
   IMMO-IDENTNR: VWZ7Z0W0678635
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
            30-10 - Open or Short to B+ - Intermittent
Address 46     -------------------------------------------------------
   Controller: 1J0 959 799 J
   Component: 16 Zentral-SG Komf.0002
   Coding: 04096
   Shop #: WSC 00028
6 Faults Found:
00953 - Interior Light Time limit
            25-10 - Unknown Switch Condition - Intermittent
00928 - Locking Module for Central Locking: Front Driver Side (F220)
            27-10 - Implausible Signal - Intermittent
00929 - Locking Module for Central Locking: Front Passenger Side (F221)
            27-00 - Implausible Signal
00930 - Locking Module for Central Locking: Rear Left (F222)
00935 - Electric Window Motor: Rear Right (V27)
            62-00 - No or Incorrect Adjustment
00931 - Locking Module for Central Locking: Rear Right (F223)
End   -------------------------------------------------------
2nd test
   Coding: 04000
   Shop #: WSC 00028
   Coding: 13504
   Shop #: WSC 00028
   Coding: 00065
   Shop #: WSC 00028
1 Fault Found:
            35-00 - -
   Coding: 04442
   Shop #: WSC 00028
   Coding: 04096
   Shop #: WSC 00028
just hoping it stays like this...no airbag light at all now, apart from the flashing to advise me the passenger one is deactivated...
Offline hardmonkeys
« Reply #22 on: 01 April 2013, 14:39 »
in the central locking section on VAGCOM...it comes up the the Vag Number, Component, Soft. Coding, Shop# and 2 boxes for Extra,
In these boxes i have
1J2959802C 16 Torsteuerger FS0001
1J2959801D 16 Torsteuerger BF0001
1J4959811C 16 Torsteuerger HL0001
1J4959812C 16 Torsteuerger HR0001
Any ideas what the 'extras' are??
