Author Topic: Advice on crushed jack point please  (Read 7788 times)
Offline TwoGapper
« on: 23 March 2013, 19:16 »
Had car on jack recently (flat front driver side tyre ) it crumbled...
Took it to auto shop, he said it wasn't too bad but a little corrosion around that area, he showed me the length of it on ramp it sort of looked clean to the naked eye underside of car looked pretty decent AFAIK but I don't know what I'm doing. But I can't jack the car now and I also wonder about the integrity...
Say it's just a small area around jack point, is that likely an MOT fail???
How long would the sills last if left that way.. or if I have a patch welded in (he quoted £200 both sides) how long would that extend life expentancy... ?? I also think I will have to buy a trolley jack and avoid using the sills. Can a novice do this?? I can see that not being ideal in busy traffic..
Alternitively, I may sell it.. it's a very nice P reg Golf 1.8 SE dark blue with GTI trim with sunroof in very good condition with 95k on clock and history etc, starts every time, original 14" alloys could do with refurbing.. what's it worth..??
Sorry for all the questions.. I have limited funds and don't know what to do  :undecided:
Offline itavaltalainen
Re: Advice on crushed jack point please
« Reply #1 on: 23 March 2013, 19:39 »
there is another thread here about someone who needs to replace sills.... just go down, say 5 threads ;)
Gavv8
« Reply #2 on: 23 March 2013, 19:56 »
This is a common issue with the mk3, invest in decent trolley jack as they are much safer and very easy to use and avoid jacking on any of the sills or underbody panels, best places to jack a mk3 are under rear subframe mounting points just behind and to the front of the rear wheels and under the front subframe or front engine mount behind the radiator.
« Last Edit: 23 March 2013, 19:57 by Gavv8 »
Offline Callum_K
« Reply #3 on: 23 March 2013, 23:34 »
To be honest a mk3 without crushed front jacking points is a rare sight lol. If its only surface rust just try straightening it out, grind of the rust and seal it up. As for whether its an MOT failure it depends on the garage...
Gavv8
« Reply #4 on: 24 March 2013, 07:46 »
Mine doesn't have any.... :smug:
Offline Shady Pioneer
  • graphic designer.
« Reply #5 on: 24 March 2013, 10:28 »
My sills are looking a bit worse for wear lately so come the summer I'm going to have then completely redone. Last night I needed all four wheels off whilst I was painting my calipers so I hacked the car up from the front engine mount, and the rear subframe for the rear.
Much easier and safer.
I'd leave the sills alone at all costs.
VW BUSH
« Reply #6 on: 24 March 2013, 13:38 »
If it crumbled then it needs welding, don't leave it to long or it will massive as the front wheels flick all the sht up there.
A 2t jack can be had for £30 in a case.
Offline murraymint
« Reply #7 on: 24 March 2013, 13:56 »
This is what I did after spending ages fitting new sills a quick before and after for you
josh
Offline dan_thevdub_man
« Reply #8 on: 24 March 2013, 18:16 »
what did you do mate? how long and how much did it cost?
Offline murraymint
« Reply #9 on: 24 March 2013, 18:52 »
I cut out the old sills and welded in new ones then filled over the welds and the car had a full respray. Doing the sills didn't take that long, just took me so long as I was doing it after work and at weekends. Didn't cost much as I did all the work  :cool:
josh
