Author Topic: Performance Manifold Questions?  (Read 1712 times)
Offline MickP mk3
« on: 23 March 2013, 14:16 »
Iv been looking at performance manifold for my 8v gti, but don't think they will make enough power to be worth £200ish. what realistic gains do you get from them? Is it worth trying to get a second hand one if I can find one cheap enough?
Offline Foreveryoungaus16v
Re: Performance Manifold Questions?
« Reply #1 on: 23 March 2013, 14:26 »
None, waste of money.  Get your flywheel lightened instead for that money.
« Last Edit: 23 March 2013, 14:30 by Foreveryoungaus16v »
163 BHP (TSR POWER RUN)
Offline MickP mk3
« Reply #2 on: 23 March 2013, 14:45 »
I had thought of that but wasn't planning on spending the £200. I was going to hold out for a cheapy or fabricate my own tubular manifold (which iv done before, if I can find some measurements I can make one for around £50 and good few hours). Can you buy pre lightened flywheels from somewhere? Or is at remove and find some to do my original flywheel?
« Last Edit: 23 March 2013, 14:54 by MickP mk3 »
Gavv8
« Reply #3 on: 23 March 2013, 14:53 »
I wouldn't bother.. you'll only be back in a few days to ask how to fix all the bits you broke trying to change it, go for a nice drive down to the beach and have an ice cream as its a lot less stressful and your standard 8v will get you there and back with no problems.
« Reply #4 on: 23 March 2013, 14:57 »
Hotgolf (Mart) off Club GTI lightens and balances flywheels (he just done mine for my 16v).  He charges £69 to do this but you have to supply your own flywheel.  Just buy one from a breakers or off ebay and then you can sell your current one when its all done :smiley:
« Last Edit: 23 March 2013, 14:59 by Foreveryoungaus16v »
Offline MickP mk3
« Reply #5 on: 23 March 2013, 15:21 »
Sweet. I thought I would be more to get one lightened. Will definitely look into that. Cheers
« Reply #6 on: 23 March 2013, 15:29 »
It just not the cost of the lightening.  It cost me £100+ to get a flywheel then have it lightened.  Gonna cost
me another £100+ to get it fitted and while flywheel is off its best to change clutch which is another £100.
But hopefully all worth it in the end :smiley:
Offline MickP mk3
« Reply #7 on: 23 March 2013, 16:22 »
£25ish for a secondhand flywheel off ebay and I would do the the fitting with my mate who's mechanic. So works out not to bad:-)
« Reply #8 on: 23 March 2013, 16:56 »
Thats good.  I would recomend changing your clutch while you are at it tho :cool:
