Author Topic: troubles on start up  (Read 1302 times)
Offline nhop10
  • Mk3 GTi
« on: 23 March 2013, 00:42 »
tried a search but nothing quite like this. more about getting the car started.
Anyways i got a mk3 gti 8v, has been running ok until recently, apart from having to change the coilpack and battery during the last cold spell. on start up the idle has been a bit low and struggling, sometimes stalling. after reving it up for a few minutes or driving down the road a little then its all good and the car will idle as normal. when i say a little i mean not too long at all, way before the temp guage is up. would this be a sensor of some kind causing the issue?
cheers in advance
Mk1 Golf 1.1, 6n Polo 16v, and now an 8v mk3 GTi
Offline dan_thevdub_man
Re: troubles on start up
« Reply #1 on: 24 March 2013, 18:52 »
any luck with this mate, im having the same issue
Offline nhop10
  • Mk3 GTi
« Reply #2 on: 24 March 2013, 20:10 »
no such luck, anyone got any ideas? i have a slight oil leek around the head, just wondered if this was related?  :huh:
Offline dixie180
  • Mk3 8v Gti,Mystic Blue the best colour.
« Reply #3 on: 24 March 2013, 20:27 »
Hi bud,have you checked the condition of the throttle body to see if its full of crap.This can cause poor idling sometimes.Check temperature sensor aswell  :smiley:.
« Last Edit: 24 March 2013, 21:19 by dixie180 »
Offline dixie180
« Reply #4 on: 25 March 2013, 12:10 »
Hi nhop10,when you say you have a slight oil leak around the head do you mean the rocker cover and is the leak around that cover above the spark plugs?.If so,then you need a new rocker cover gasket and this is quite normal,unfortunately :sad:.
