Author Topic: when to replace n75 valve and which letter?  (Read 3117 times)
Offline davemk4
« on: 22 March 2013, 21:52 »
not the usual which is better question. me car (aum) done 118k. if i were to renew the n75 valve on my 2001 1.8T. what is the correct upto date letter? is it E,F or J?
just wondered if the valve had lost some of it upmf over time  :smiley:
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: when to replace n75 valve and which letter?
« Reply #1 on: 23 March 2013, 07:49 »
E is the current version
Offline davemk4
« Reply #2 on: 23 March 2013, 10:52 »
Can get E for about 35 new. Do you thnk worth replacing? Due to milage. Any advantage E over F
Offline Nino
« Reply #3 on: 23 March 2013, 18:03 »
Im thinking about this too where can u get the. For £35 new!? And would that be a gen part??
Current - MK6 GTi Edition 35
Offline davemk4
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 23 March 2013, 20:15 »
That's cheap
Offline 1.8t-net
« Reply #6 on: 23 March 2013, 21:47 »
I have a 2001 AUM and I suspect my N75 is iffy.  Is there a way to check it before I purchase?  I don't want to waste £38.99
Offline mar_k
« Reply #7 on: 24 March 2013, 13:34 »
Wazzer what about the F version, Is that before or after the E version?
I thought F has superceeded the E?
http://www.ebay.co.uk/itm/SEAT-N75-valve-standard-version-058-906-283F-Genuine-/261180590912?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3ccf938b40
I'm about to buy a new one so would love know the answer, Cheers
Offline davemk4
« Reply #8 on: 24 March 2013, 20:26 »
yer youd expect that the F be the newer type not e....
Offline Scott D
« Reply #9 on: 24 March 2013, 20:34 »
E defiently is the newer version, odd use of the alphabet
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
