Author Topic: when to replace n75 valve and which letter?  (Read 3123 times)
Offline davemk4
Re: when to replace n75 valve and which letter?
« Reply #10 on: 25 March 2013, 19:22 »
So any change in the E over F? Worth replacing as it 10 year old
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline Dalo Harkin
« Reply #11 on: 25 March 2013, 19:42 »
No one has answered in terms of how you know if it needs replacing, I would like to know this too obviously providing no fault code etc how long should they last for and are there any benefits replacing to a newer version
Offline davemk4
« Reply #12 on: 25 March 2013, 19:58 »
This is it. I know J valve has very mixed views
Offline novadragon007
  • Love at first clutch bite...
« Reply #13 on: 25 March 2013, 20:05 »
i think its logging in vag com group 118 to check if its faulty something to with the cycle percentage but im not exactly sure on what to look for in it lol
Mk4 GTi 1.8t 16" BBS Alloys, Coilovers, Full Exhaust, Catch can..... More to come - If i ever beat this 17705
Offline 1.8t-net
« Reply #14 on: 25 March 2013, 20:58 »
Does anybody know how I can test this before shelling out on a new one?
Offline davemk4
« Reply #15 on: 26 March 2013, 16:36 »
Looks like no one knows lol :-(
Offline Dalo Harkin
« Reply #16 on: 26 March 2013, 20:30 »
 :sad:
Gutted too... wanted to see if mine was up to the job, don't think it's ever been changed
Offline jimmyGIT
« Reply #17 on: 27 March 2013, 08:19 »
Read sumthing about blowing into the tip side to see if any air passes through if so its fecked!It operates like a one way check valve but electronically, so this kind of makes sense!! :undecided:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #18 on: 27 March 2013, 08:43 »
Yes one pipe should be blocked and the other two you should be able to blow through
Offline Dalo Harkin
« Reply #19 on: 27 March 2013, 09:06 »
to put it another way then, what would be the characteristics of a faulty N75  :evil:
