Author Topic: Hybrid K03s  (Read 5527 times)
Offline asboGTI
Re: Hybrid K03s
« Reply #20 on: 26 March 2013, 07:26 »
Right so con rods will be sorted thanks to another member  :grin:
So what else will I need when fitting it already gonna change sump just what else is needed
vw golf mk4 ARZ 1.8T pipercross panel filter, xenon headlights, JOMS coilovers, forge 007p with green spring, audi tt anti roll bar, 3inch ebay trubo back exhaust, COOKIES MONSTER STICKER(adds bhp I swear)
Offline beppe2672
Re: Hybrid K03s
« Reply #21 on: 26 March 2013, 08:57 »
Your gonna need a full set of gaskets for your turbo. New bolts/studs/nuts to attach it to the manifold and down pipe, it's advised you do an oil and filter change too. You're also gonna need a bit of coolant. Speak to the r-tech guys about what fpr they reckon you'll need. Your fuel pump may require upgrading also. It may be worth getting either a high flow exhaust manifold or getting your oem one ported to help keep your egt's low and increase flow.
1999 1.8t AGU, KNN Panel filter, Smoothed air box, Custom CAI, Forge 007 dv, REVO stage 1, 3" eBay TBE. Audi TT quickrack.
To come - A DIY hybrid K03 and a whole lot of supporting mods!
Offline asboGTI
Re: Hybrid K03s
« Reply #22 on: 26 March 2013, 09:02 »
Beppe just emailed r-tech as you just suggsted and so basically replace as much as possible when doing it was gonna use all new bolts for turbo just out of principle so glad I was thinking along he right lines
Offline golfyste
  • Project track car
Re: Hybrid K03s
« Reply #23 on: 26 March 2013, 12:03 »
Change the pick up pipe too is your doing the sump.  :smiley:
Offline asboGTI
Re: Hybrid K03s
« Reply #24 on: 26 March 2013, 13:28 »
ok well is seen a baffled sump and hybrid shallow sump but duno which i will get swinging more towards the baffled sump to prevent even a little bit fo oil starvation
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Hybrid K03s
« Reply #25 on: 26 March 2013, 16:18 »
Part numbers you'll need for the turbo swap are in the maintenance section
Offline asboGTI
Re: Hybrid K03s
« Reply #26 on: 26 March 2013, 16:21 »
wazzer again your tooo good at this sweet cheers
Offline asboGTI
Re: Hybrid K03s
« Reply #27 on: 26 March 2013, 17:03 »
this clutch should be ok in my mind so i better get saving my pennys
http://www.awesomegti.com/car/vw/golfmk4/ecs-stage-1-clutch-kit-228mm-5-speed-55861
Offline beppe2672
Re: Hybrid K03s
« Reply #28 on: 26 March 2013, 22:12 »
Go for baffled sump mate, unless you're running low.
Offline asboGTI
Re: Hybrid K03s
« Reply #29 on: 26 March 2013, 23:38 »
I won't be running decked but I will be low enough that 18's fill the.arches
