Author Topic: Hybrid K03s  (Read 5524 times)
Offline jonnyturbo
Re: Hybrid K03s
« Reply #10 on: 24 March 2013, 10:51 »
You won't need pistons so spend that money elsewhere
+1 on that I had a k03s hybrid on my golf when I had it and I didn't do the pistons or the rods . so like waz says spend the money else where .
Offline asboGTI
Re: Hybrid K03s
« Reply #11 on: 24 March 2013, 11:49 »
I checked with littco when I picked it up and he said get rods this is a 300bhp that miles had the same spec and he blew his engine up so doing everything I can to stop so a clutch will be brought instead of pistons but I am still getting rods cause I am guessing it will be quite torquey  :evil: but need to know om the wrist pin wether it's 19mm 20mm or 21mm
vw golf mk4 ARZ 1.8T pipercross panel filter, xenon headlights, JOMS coilovers, forge 007p with green spring, audi tt anti roll bar, 3inch ebay trubo back exhaust, COOKIES MONSTER STICKER(adds bhp I swear)
Offline beppe2672
Re: Hybrid K03s
« Reply #12 on: 24 March 2013, 16:27 »
What's your engine code?
1999 1.8t AGU, KNN Panel filter, Smoothed air box, Custom CAI, Forge 007 dv, REVO stage 1, 3" eBay TBE. Audi TT quickrack.
To come - A DIY hybrid K03 and a whole lot of supporting mods!
Offline jonrandom
Re: Hybrid K03s
« Reply #13 on: 24 March 2013, 16:52 »
Its in his sig mate, ARZ
Offline beppe2672
Re: Hybrid K03s
« Reply #14 on: 24 March 2013, 17:06 »
That would be 19mm wrist pins I believe. If you still want different pistons you could get a set of 20mm wrist pin con rods and chuck a set of agu or bam pistons in?
« Last Edit: 24 March 2013, 17:30 by beppe2672 »
Offline asboGTI
Re: Hybrid K03s
« Reply #15 on: 24 March 2013, 17:41 »
Yeah but are the pistons from a bam even worth it cause am.thinking about the scene tax lol
Offline beppe2672
Re: Hybrid K03s
« Reply #16 on: 24 March 2013, 17:44 »
The only difference in the bam pistons are the 20mm wrist pins and a slightly lower compression ratio, 9.3:1 instead of 9.5:1 not sure they're worth it unless you can get them cheap!
Offline asboGTI
Re: Hybrid K03s
« Reply #17 on: 24 March 2013, 19:45 »
Cheer at least its gives something to think about anyone got ideals about a good clutch and where to gt it for this
Offline beppe2672
Re: Hybrid K03s
« Reply #18 on: 24 March 2013, 20:40 »
I reckon you'd be fine in stock pistons. Clutch wise it depends, if this is gonna be your daily driver I'd stick with the usual g60 flywheel and vr6 clutch combo. If you're after anything stronger than that its depends on your wallet!
Offline asboGTI
Re: Hybrid K03s
« Reply #19 on: 24 March 2013, 20:46 »
Well the problem is it will be a daily but will be running over 300bhp and as I said will be quite torque from.what I understand so I wasn't sure if the g60 vr6 would hold or not. Piston wise I am gonna leave them unless I manage to finds them cheap enough and I doubt they will make a massive difference anyway
