Author Topic: stalling/hesitation and fuel relay clicking  (Read 8240 times)
Offline Callum_K
Re: stalling/hesitation and fuel relay clicking
« Reply #20 on: 21 March 2013, 17:02 »
Try the relays first as they're cheap, if that doesn't fix it try the crank sensor. Just make sure you get VW or an OE quality aftermarket one. The Premium one from Eurocarparts on my car has been fine, the cheaper failed in 3 days, got my money back on it though!
Offline GOLF-MK3-GTI
« Reply #21 on: 21 March 2013, 17:06 »
I got my crank sensor from GSF, Still going strong  :cool:
Offline Batts91
« Reply #22 on: 21 March 2013, 17:45 »
do you mean this one?
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf_2.0_1997/p/car-parts/engine-parts/fuel-and-engine-management/engine-management-sensor/?494440201&1&748e01af0931f9cdc13285d6e8b6365e2c00f9a3&000440
or this ??
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf_2.0_1997/p/car-parts/engine-parts/fuel-and-engine-management/engine-management-sensor/?494440200&1&4b111189b03ac1f9be75d7c61ce594ba8b55c207&000440
Offline dixie180
  • Mk3 8v Gti,Mystic Blue the best colour.
« Reply #23 on: 22 March 2013, 14:13 »
I'd go for the Delphi one or if you can afford it a Bosch one,but they will knock you back about £100. :shocked:
Offline Callum_K
« Reply #24 on: 22 March 2013, 14:44 »
The £55 one is the one you want! Can't remember what brand it is but mine has been fine.
Offline wayedy
  • GTI FOR LIFE
« Reply #25 on: 23 March 2013, 04:11 »
Any luck mate?
[/URL]
Offline Batts91
« Reply #26 on: 24 March 2013, 12:17 »
Not just yet , im waiting for a relay to come from Volksbits in the post , either monday or tuesday . There parts are very reasonably priced on ebay.
Then ill drive the car untill it happens and replace and see results :)
Offline Batts91
« Reply #27 on: 28 March 2013, 15:07 »
I still have this problem ! .
Replaced fuel pump relay and taxed car today , started fine .
Drove about for say 15-20mins boom !!
Bogging out backfiring at 2500rpm ish . Somtimes at 3k .
Found a suitable place to pull over and i have a vid to explain what happened .
After this vid i walked to a shop got meself a drink and more smokes ! I got back to the car exactly 2mims later , temp gauge was still in centre 90deg .Turned key it was sweet as fook :/ so drove the say 5 min remainder home if that ! .
If im right in thinking this could be a temperature switch/sensor still telling the engine its cold and in essence giving more fuel when not needed ! ??
Video is just uploading via photobucket will post link asap !
Offline kylepeo
  • Vw's never die they just get lower !!
« Reply #28 on: 28 March 2013, 15:18 »
Ecu Relay they where a known issue with vw if not the relay then go with crank sensor
Vw\'s never die they just get lower !! :):)
Offline Batts91
« Reply #29 on: 28 March 2013, 15:37 »
i dont mean to question you as ive heard thos are very common issues with the mk3 but, what about the fact its ok after 20 minutes ? would this factor into those issues ?
Many Thanks James
