Author Topic: stalling/hesitation and fuel relay clicking  (Read 8254 times)
Offline Batts91
« Last Edit: 28 March 2013, 16:09 by Batts91 »
Offline Callum_K
Re: stalling/hesitation and fuel relay clicking
« Reply #31 on: 28 March 2013, 16:21 »
Crank sensor can fail when it gets warm, won't restart, leave 10 minutes to cool, then it will be fine, sometimes for minutes, sometimes days before it cuts out again. Replace it with an OE one!
Offline Callum_K
« Reply #32 on: 28 March 2013, 16:35 »
And fuel relay is clicking on/off because the ECU keeps cutting out the fuel pump when it loses the crank sensor signal.
Offline Callum_K
« Reply #33 on: 28 March 2013, 16:37 »
If its not your crank sensor I will eat my hat.
Offline Batts91
« Reply #34 on: 28 March 2013, 16:57 »
im still in contact with the person i got the car off and he sent me this link wich is what he bought and fitted from ebay just before i bought the fooker .
http://www.ebay.co.uk/itm/400419490696?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
What you are saying makes perfect sense sir , this cheap and nasty sensor has probably gone duff in a matter of minutes !
Offline GOLF-MK3-GTI
« Reply #35 on: 28 March 2013, 17:27 »
Listen to what this good man is saying.
My car had exaclty the same symptoms, it was crankshaft sensor. after looking at video, i'm 110% sure it is that  :wink:
Offline dixie180
  • Mk3 8v Gti,Mystic Blue the best colour.
« Reply #36 on: 28 March 2013, 17:33 »
+1
Offline Batts91
« Reply #37 on: 28 March 2013, 17:53 »
ok sweet , cheers guys !! What brand do you recommend ??
ecp doesn't say what brand this is but would this be efficent ? I'm on a tight budget lol.
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf_2.0_1997/p/car-parts/engine-parts/fuel-and-engine-management/engine-management-sensor/?494440200&1&4b111189b03ac1f9be75d7c61ce594ba8b55c207&000440
Offline dixie180
« Reply #38 on: 28 March 2013, 18:59 »
It does actually say Delphi on left hand side of screen under where you put your cars reg no. :smiley:.Like i've said before if you can afford a Bosch one then get that,but as your on a budget this should be ok.
Offline Batts91
« Reply #39 on: 28 March 2013, 19:37 »
Ahhh yess i did not see that ,Thanks .
My budget is rather low , trying to save the pennys and not alot of work due to weather . There is a cheaper sensor on Ecp but has no brand name in the box like the Delphi. But i shall plunge and get the best i can afford which is the Delphi .
Thanks for help and i shall return with results once i have fitted new sensor . Thanks
