Author Topic: pneumatic eh!!! central locking  (Read 4952 times)
Offline mysticman aka polypathetic
« on: 11 October 2003, 21:01 »
can anyone help my central locking has packed up on all doors apart from the drivers door, which works on the alarm,worst of all some little sh!te  (kid) from my area could easily get into my petrol tank, you know where i'm going  with that. please help anyone got any ideas :-[
Blue MK2
Re:pneumatic eh!!! central locking
« Reply #1 on: 11 October 2003, 21:19 »
Have a look in the boot near the rear lights for disconnected hoses
Offline Dizzie
  • Make friends with your fast
« Reply #2 on: 11 October 2003, 22:04 »
to lock your petrol cap there's a looped rod behind the carpet near the cap. push it towards the front of the car to lock it and then the other way to underlock when u need to fill up :)
« Last Edit: 11 October 2003, 22:04 by Dizzie »
« Reply #3 on: 12 October 2003, 10:36 »
thanks people
all seems to be conected and i have power to the pump in the boot but where is the sender unit to the pump as im guessing its been disconnected by some idiot inthe past and with regards to opening the boot everytime i want to fill up, to much likehard work need the easy life..... ;D
Offline dan allen
« Reply #4 on: 12 October 2003, 11:35 »
did it work before?
sometimes the factory central locking is made immobile by companies fitting remote alarm systems.
if your pump/solenoids are knacker ive got a set for sale
« Reply #5 on: 12 October 2003, 18:17 »
so what are you saying for the pump and stuff cos i need these doors to unlock and lock when asked  let me know
cheers
 ;Djay
also central locking has never worked since i got the car so i'm working to a process of elimination
« Last Edit: 12 October 2003, 18:19 by polypathetic »
Offline dan allen
« Reply #6 on: 12 October 2003, 23:49 »
40quid the lot ok ?
Offline Helios_Blue_Valver
« Reply #7 on: 15 October 2003, 02:08 »
if the pump is working and the hoses are all fine then it could very well me the master actuator in the drivers door. this is what sends the signal to the pump to start pumping. according to the bently manual the pump should only run for about 2 seconds before cutting off. Does it run when you turn the key to unlock?
Offline modulater
« Reply #8 on: 15 October 2003, 02:10 »
The electrical sender that makes the pump energise is in the drivers door. It forms part of the normal locking mechanism and I would check it hasnt been removed and replaced with the alarm solenoid you describe. Take the door panel off and you should see it.
It has a power feed live all the time and two feeds back to the pump, one to lock and one to unlock.
Normal practise is to leave it in place and have the solenoid operate it so that it locks and unlocks the car as per normal.
« Reply #9 on: 15 October 2003, 22:49 »
thanks people i'll take the panel off this weekend and have a look , there is no naise coming from the pump so i'm guessing it has been disconnected from the drivers door key solinoid but i'll have a look and let you guys know
cheers again
jay
