Author Topic: pneumatic eh!!! central locking  (Read 4951 times)
Offline reserves
Re:pneumatic eh!!! central locking
« Reply #10 on: 26 October 2003, 08:57 »
Hi
I have the same problem, did you find a solution?
The drivers door works and sends a signal to the pump in the boot  which just buzzes for about a minute (it stops buzzing if I open the boot), the petrol cap, passenger door and boot do not lock.
Also I cannot lock the boot using the key so maybe this is stuck/jammed and causing the rest to fail?
Does the boot pump send the signal to the passenger door and petrol cap? Or do I have another problem?
Thanks
Rich
Offline mysticman aka polypathetic
« Reply #11 on: 26 October 2003, 21:48 »
well i'm stumped can't get the pump to work via the drivers door and it has been messed about with by the look ,the car has had a toad alarm fitted to it because i can only guess the original one went wrong, can anyone tell me where on the fuse box where the central locking enters and leaves, wire colours , a diagram could help. this is really starting to piss me off now as i am getting fed up with taking door panels off here and there and is there a test that i can do to see if the pump still works help help help f-in help >:(
Offline reserves
« Reply #12 on: 27 October 2003, 12:36 »
Does anyone know if the boot pump runs the petrol cap & passenger door??
Please!  ;)
Rich
Offline dan allen
« Reply #13 on: 27 October 2003, 18:27 »
yup the pump runs the lot m8y
