Author Topic: Standard alloy nuts  (Read 8323 times)
Offline Mark b
Standard alloy nuts
« on: 11 March 2013, 18:14 »
Does anyone know what are the standard measurements are on wheel nuts length ect basically I went to get new alloys fitted today but my wheel nuts are not long enough so I need to buy new ones but don't know what are the right ones to get
The nuts I've got at the mo are black if that helps replacing the wheels on my sig pic
Standard gti 2.0 115bhp 2000 w reg
Offline Kobe
Re: Standard alloy nuts
« Reply #1 on: 12 March 2013, 10:39 »
M14 x 1.5 x 28mm long....... standard wheel nuts mate
Offline Mark b
« Reply #2 on: 12 March 2013, 16:29 »
Cheers fella do you know what ones I'd need to fit aftermarket wheels need longer ones
« Reply #3 on: 13 March 2013, 10:51 »
Aftermarket alloys will need a different taper, standard bolts will be radius seat and are no good for the new alloys.
Offline Mark b
« Reply #4 on: 14 March 2013, 14:09 »
cheers for the info i found a place near me that sell extended nut but would i need wheel spacers with the longer nuts
« Reply #5 on: 17 March 2013, 16:29 »
What alloys are you fitting, longer bolts should not be needed
Offline Mark b
« Reply #6 on: 17 March 2013, 17:01 »
these ones mate they are 7j wide with an offset of 35 17" 5x100 i hope i dont need longer bolts hope this info means more to you then it does me
this is how much my bolts stick out the new wheel
« Reply #7 on: 17 March 2013, 17:02 »
What make are the wheels.
Offline Mark b
« Reply #8 on: 17 March 2013, 17:10 »
they are called cerberus ive never heard of them before hope this helps
« Reply #9 on: 17 March 2013, 17:17 »
