Author Topic: Sealing the garage floor  (Read 1949 times)
Offline bobbarley
  • I'm kind of a big deal...
« on: 07 March 2013, 15:18 »
I'm planning on sealing the garage floor this spring/summer, and wondered if anyone on here had tackled the job before?
If so, can you recommend any kits for doing the job?  It's a standard single garage.  also, any tips?
Offline stfc_gti
Re: Sealing the garage floor
« Reply #1 on: 07 March 2013, 16:31 »
how many bodies have you burried?
2002 1.8T GTI AUM, Standard (not for much longer)
Offline bobbarley
« Reply #2 on: 07 March 2013, 21:20 »
Many
Offline Ginge 35Edition
« Reply #3 on: 07 March 2013, 21:41 »
I'm guessing its concrete so just seal it with a pva solution ad then paint it. I'm fairly certain that some of the garage floor paints you but do both, so no need to seal first?
Offline dTEA
  • back in an MK5
« Reply #4 on: 08 March 2013, 09:44 »
Seal it then outdoor masonry paint. The others still flake anyway and cost loads more
Edition 30 / T5 T32 Kombi
Offline danny_p
« Reply #5 on: 08 March 2013, 12:23 »
epoxy floor resin.
1st coat i thinned with 50% acetone,  and literaly just tipped the bucket over and brushed it about with a sweeping brush.  acetone helps it soack in to teh concrete and really bind the top layer together as well as providing an excelent key for the top coat.
2nd coat was just straight floor resin  put on with a long handel roller ( useing the tip and spread method )
if your going to be walking on the floor when its wet or oily  you need some sand in the top coat tho else it gets very slippy
all the VW's have gone bar 1.
Offline Organisys
  • Old and Slow...
« Reply #6 on: 08 March 2013, 12:40 »
epoxy floor resin.
This 2 pack Epoxy is the way to go if you want to paint it.
http://www.regalpaints.co.uk/product/two-pack-epoxy-floor-paint-top-coat-Paint03.html
If you just want to seal it, Wickes do a good Concrete floor sealer. Mine has been down two years now with no problems.
http://www.wickes.co.uk/invt/214270
Either way, get the floor as clean (oil) and dust free as you can first.
« Last Edit: 08 March 2013, 12:43 by Organisys »
Offline bobbarley
« Reply #7 on: 08 March 2013, 15:02 »
Cool.  It's a cement floor yes, and it's brand new, so no dirt or anything on it, just dusty.
Think I'm going to go with this stuff, then paint over the top of it.
http://www.amazon.co.uk/International-5027341-Concrete-Floor-Sealer/dp/B001HBS7ME/ref=wl_it_dp_o_pC_S_nC?ie=UTF8&colid=1XFID1K5I5KX9&coliid=I27L7MJC601YMU
Offline hobbiniho
« Reply #8 on: 08 March 2013, 16:26 »
how new are we talking?? because if its still "green" you need to let it properly cure first
Offline bobbarley
« Reply #9 on: 08 March 2013, 18:30 »
6 months old maybe.
