Author Topic: fuse keeps blowing on heated rear screen... what to check?  (Read 1601 times)
Offline boneybradley
  • Back in a Mk3...
Well I have a small issue with my heated rear screen, it keeps blowing the fuse. I have changed the switch for one I know is fine and checked the wiring (as much as possible)
Are there any other things to check?
I am guessing the earth but I don't know where that is located, and what do i need to check, also it's possible i have a faulty heated mirror which i guess would cause the same fuse blow as they share the circuit?
any advice welcomed
Offline WeekendMechanic
  • Golf MK3 GTD
Re: fuse keeps blowing on heated rear screen... what to check?
« Reply #1 on: 28 February 2013, 17:38 »
Did you check the wires in the rubber bellow, could be touching to an earth wire causing the short circuit....
« Last Edit: 28 February 2013, 18:01 by WeekendMechanic »
Offline javalin
« Reply #2 on: 01 March 2013, 10:59 »
check the resitance across the heating element, then you can calculate the load (amps) and that might explain the blowing fuses.  Does it blow instantly when turned on, or after a while?
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
  • Back in a Mk3...
« Reply #3 on: 01 March 2013, 11:40 »
it's hard to say, I think it blows with the ignition? (It was fine until i restarted the engine... I think?)
I will check resitance this weekend, I am also going to unplus it and see if the mirrors blow it?
Offline javalin
« Reply #4 on: 01 March 2013, 11:50 »
yeah check anything else on that fuse too.
Offline Bellend
« Reply #5 on: 01 March 2013, 12:41 »
Does it blow with switch off and ignition on?
Where all my moneys went.
  • Back in a Mk3...
« Reply #6 on: 01 March 2013, 15:28 »
I will check that when I get some new fuses this weekend! i think it's only when the switch is turned on and ignition is initially turned on (it seems to be fine other times?)
