Author Topic: Servicing  (Read 2998 times)
Offline M3 SHAM
Servicing
« on: 27 February 2013, 12:43 »
Hi Guys
was hoping someone could shed some light on the differences between the normal and long life servicing on the Mk6 Golf 2.0 TDI (GT 140BHP)
As I understand
Normal service = 10,000 miles or 1 year what ever comes sooner
Long life = 20,000 miles or 1 year whatever comes sooner
Is a different engine oil/filter used to achieve this? or is it just an adjustment on the OBC?
My car is currently set on normal service but a change of circumstances means that I will have done just under 20,000 miles within 12 months of the last service, I would expect that the service light would flash up after 6 months.  Would there be any harm ignoring it and servicing it when it has been 12 months since the last service? (car would have covered 18,000 - 19,000 miles at this point?)
Thanks
Offline Mr GTD
Re: Servicing
« Reply #1 on: 27 February 2013, 14:05 »
If the light comes on I personally wudnt ignore it for to long as its on for reason and potentially ignoring it for to long will surely do more harm than good...I think there is a time limit in which you have to have had the service done from when the light appears...I'm sure someone can elaborate on this..?
Offline M3 SHAM
Re: Servicing
« Reply #2 on: 27 February 2013, 14:11 »
These are my concerns also, i think i need to try and find out if there are actually any differences between a normal service and a long-life service?
Offline Mr GTD
Re: Servicing
« Reply #3 on: 27 February 2013, 14:15 »
Don't know if you've read servicing this is what VW say on the matter...
Offline Buck
  • Das Auto
Re: Servicing
« Reply #4 on: 27 February 2013, 19:46 »
Further to the above, my understanding is that the oil for long life is different to the fixed 10k one.
Jimmymature
Re: Servicing
« Reply #5 on: 27 February 2013, 20:51 »
I thought the opposite, I remember reading ages ago that it's the same oil that is used.
Jim
Offline SRGTD
Re: Servicing
« Reply #6 on: 27 February 2013, 22:31 »
If you're on the time and distance servicing regime, then as you've said, the service interval is 10,000 miles or 12 months, whichever occurs first. If your car's under warranty, I wouldn't risk running up to 18,000 - 19,000 in 12 months under 'time and distance' before you get your car serviced; if you need any work done under warranty, you're just giving VW a reason to not carry out warranty repairs and / or void your warranty on the basis that the vehicle hasn't been serviced in accordance with VW's requirements, so technically you'd be in breach of the warranty conditions - see the copy of the warranty servicing requirements below from VW's website.
You can have the service regime changed to long life from time and distance, when you get it serviced.
Servicing
Your vehicle should be serviced in accordance with the manufacturer's recommendations. Any damage to or defect in the vehicle caused by poor or insufficient servicing will not be remedied under the vehicle's warranty. Please ensure that you maintain sufficient records to enable our Authorised Network to confirm that the vehicle has been appropriately serviced. In any event, please ensure that the service schedule booklet in your vehicle is stamped by the business carrying out the service work.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline M3 SHAM
Re: Servicing
« Reply #7 on: 28 February 2013, 14:04 »
Servicing
Car is 2009 so is out of warranty so nothing to worry about on that front.
From reading in to this it just seems that I may be paying for a service when it may not necesserilly be required.  If the same oil and filters is used irrespective of wether it is a 'fixed' service or 'long life' what difference does a a flashing notification on start up actually make apart from being a little annoying?  I mean it does not appear to change anything in the engine irrespective of the setting so what difference does it actually make?
When I do service it which will proberbly be at a reputable indy if it is showing as say 18,000 miles since last service then the service histroy would just appear to look as if the car was set to 'long life'
Offline Buck
  • Das Auto
Re: Servicing
« Reply #8 on: 28 February 2013, 14:36 »
Jim
You might be right Jim but when I asked at my VW Dealer what the difference was, he said the oil they use for the long life is a higher spec to take into account the longer time period/mileage?
It might have been bull?
Offline M3 SHAM
Re: Servicing
« Reply #9 on: 28 February 2013, 15:40 »
Jim
Dont know if this differs depending on dealers but I have spoke with service desk at Nottingham Volkswagen who have confirmed they use the same oil irrespective of service types
