Golf mk3
hardmonkeys
Change AGG oxygen sensor?
Topic: Change AGG oxygen sensor? (Read 3501 times)
madsb
GTI forum regular
25 February 2013, 18:03 »
Hey guys. Just got a reading on my car saying the oxygen sensor is completely out... Hopefully that explains my sh!tty mileage...
Anyway:) , which replacement should I get? Looking for the cheapest, not original VW or Bosch or w/e. Also how many leads is it? Any guides on changing it? Appreciate any links
Cheers.
benvictors
bgk Tuning - coming soon!!!
Re: Change AGG oxygen sensor?
25 February 2013, 18:08 »
The cheapest is likely to fail on install or shortly after with something like this, even the genuine ones can be tempremental. Just one plug, sits on a bracket on top of the driver side engine mount, best off trying to un-do the sensor itself when the exhaust is still pretty warm, be careful not to burn yaslef tho
gazpowells
25 February 2013, 21:33 »
can be very tight mate and sometimes easier to remove cat and get in the vice
madsb
GTI forum regular
26 February 2013, 07:12 »
Does anyone have a pic of its location? And how hard do you reckon it will be?
javalin
26 February 2013, 12:18 »
if its not seized in, its easy enough as long as you can get under the car. Its just before the cat, just behind the engine bay. You'll need a set of crows-foot spanners, to get a purchase on it.
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
madsb
GTI forum regular
26 February 2013, 14:40 »
Any specific links and info on model of oxygen sensor? How many leads? AGG engine. Cheers.
javalin
Reply #6 on:
26 February 2013, 20:17 »
4 wires from memory - get a bosch one, don't get a cheapo rubbish. Mine was either £45 or £60 from memory.
madsb
GTI forum regular
Reply #7 on:
26 February 2013, 21:07 »
So this should fit?
http://www.ebay.co.uk/itm/UNIVERSAL-LAMBDA-SENSOR-OXYGEN-SENSOR-4-WIRE-HIGH-QUALITY-/250984739999
sharki786
GOT BOOST??
Reply #8 on:
26 February 2013, 21:29 »
Mate like everyone has said dont get a cheapo one as it wont last. Thats a cheap one. You need to get bosch one as it will last longer. You need to buy one that has the plug on, it this dont.
Go cheap replace twice!!!
*****MK3 Anniversary*****
*****MK4 GTI T*****
spudboy6
Just like a golf ......
Reply #9 on:
26 February 2013, 22:25 »
The above sensor in the link will NOT work. When you wire it up the extra plugs / connectors alter the resistance to and from the sensor giving false readings and therefore not working putting you back to square one
Golf mk3
hardmonkeys
