Author Topic: Car was not handling well, found the reason why!  (Read 4540 times)
Offline Godzilla
  • <<<VR6 MADNESS>>>
« on: 24 February 2013, 23:18 »
My VR6 converted to a 20vt by previous owner. Well since owning her I thought she did not feel right, not like my VR6 in my av' pic. I did the usual kick on all 4 tyres and all seemed good and looked good, no signs of looking flat. Today I decided just to check what pressure they were running at expecting to see 32-34psi due to being 17's. Front  drivers was 22psi, rear drivers side 18psi, front passenger side 32 psi, rear passenger side 17psi.......So now all at 33psi, what a difference, cant believe I did not check this earlier  :whistle:
Normally it is visible or to touch, all tyres felt rock solid?  Oh well, all done and sorted now but thought I had to tell!  MPG and speed should be up a bit now  :grin:
Offline Khare
  • The bear that khares
Re: Car was not handling well, found the reason why!
« Reply #1 on: 24 February 2013, 23:32 »
Tyre pressures, fluid level check and a quick visual inspection is something I do weekly religiously.
Offline murraymint
« Reply #2 on: 24 February 2013, 23:48 »
Same here, but more because I'm paranoid that something's wrong  :laugh:
josh
Offline tweed
« Reply #3 on: 25 February 2013, 06:12 »
Christ with it being so cold I check mine once a month.
I have very good quality stainless steel valves, that don't leak as much. But being cold and air smaller it can escape easier.
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #4 on: 25 February 2013, 09:25 »
I normally do mine every 14 days!  Never knew how bad low pressure tyres and out of sync' regarding pressures it would have on the car......Shocking
Offline Len
« Reply #5 on: 25 February 2013, 13:07 »
I would say that 32 is too high!
I have my fronts at 30 and rears at 28
www.sas.org.uk
www.the-ace.org.uk
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #6 on: 25 February 2013, 16:07 »
Thanks Len.  Just got in after reading this and my fronts are 30 and rears 28  :smiley:
Offline GOLF-MK3-GTI
« Reply #7 on: 25 February 2013, 16:11 »
ive got 205/50/R15 and i've always had 38 in mine all way round. :tongue:
Offline tweed
« Reply #8 on: 25 February 2013, 16:14 »
In winter when roads are cold you need higher pressure to get heat in the tyre faster. I run 36 front 32 rear.
Summer I run 32 front 28 rear. Summer you get more heat in them and the air pressure will rise 2/4 pounds.
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #9 on: 25 February 2013, 17:24 »
I see.....Thanks  :wink:
GOLF-MK3-GTI  Your car must be ultra bouncy  :grin:
