Author Topic: Car was not handling well, found the reason why!  (Read 4542 times)
Offline tweed
Re: Car was not handling well, found the reason why!
« Reply #10 on: 25 February 2013, 17:40 »
In winter when roads are cold you need higher pressure to get heat in the tyre faster. I run 36 front 32 rear.
Summer I run 32 front 28 rear. Summer you get more heat in them and the air pressure will rise 2/4 pounds.
I see.....Thanks  :wink:
GOLF-MK3-GTI  Your car must be ultra bouncy  :grin:
No it will be stiffer  :wink:
Offline GOLF-MK3-GTI
« Reply #11 on: 25 February 2013, 17:47 »
Lol, It is stiff  :grin:
Offline Len
« Reply #12 on: 26 February 2013, 13:40 »
How long you had your tyres TWEED?
I just wonder because at that pressure you are probably wearing out the centre of the tyre before the edges. Also how long have you had the car and what mileage?
www.sas.org.uk
www.the-ace.org.uk
Offline tweed
« Reply #13 on: 26 February 2013, 17:17 »
I've had mk3 golfs now for 4 years 16v gti, 8v gti and a vr6.
I also have to adjust front camber to its maximum negative camber, otherwise I get outside tyre wear. I thought it was tracking but had that checked and all good.
My tyre wear even and flat. Toyo t1r didn't last long on the 16v even with tyre pressures at 27psi. They grained a lot and I cooked them. Might due to heat build up due to friction in the soft tyre wall.
I run yoko paradas on my vr6 and they are a lot better. Haven't cooked them yet and still all very even tyre wear.
I tell you what Len, shall I take a picture for you? Would that then stop you arguing with me on every thread I don't agree with you on?
Gavv8
« Reply #14 on: 26 February 2013, 19:25 »
:laugh:
Offline tweed
« Reply #15 on: 26 February 2013, 20:12 »
I mean come on! I run 32 and 28
Len has 30 and 28
 Len is saying my pressures are to high and I'm wearing out my tyres and also needs to know how long I've had my car and the mileage. Really?? Why do you need to know that?
Len you do know the standard tyre garage pressure is 32psi right?
Offline Shady Pioneer
  • graphic designer.
« Reply #16 on: 27 February 2013, 11:43 »
Tweed, have you seen Len's car? It doesn't matter what he says because his car is sh!t.  :grin:
Offline tweed
« Reply #17 on: 27 February 2013, 12:13 »
He clearly doesn't know much too.
In summer your tyres get hot! The air pressure will rise a lot!
But you hardly get them warm in winter so raising your pressure is a must.
Why do you think you only put air in cold tyres and not hot tyres?
Offline tshirt2k
  • Been there...Done that...
« Reply #18 on: 27 February 2013, 12:33 »
I think you'll find a 16v or vr6 needs quite high pressures especially if running 195/50's. look in the petrol flap. I run 38psi front 35 rear on 195/45's. 205/50's run 32 & 30. Lower profile usually run at at higher pressure and its to do with load rating of the tyre. And considering how heavy the front of the mk3 is with an ankor is or a 16v with AC on it is. It makes sense.
Those are manufactures recommended pressures. Been over this many times before. And people will still say its too high.
And no, the centre of the tyre doesn't wear.
« Last Edit: 27 February 2013, 12:40 by tshirt2k »
Mk3 ABF 16VT Megasquirt V3
Offline Len
« Reply #19 on: 27 February 2013, 12:59 »
Tweed you did not answer my question.
Running higher than necessary tyre pressures will wear out the centre of the tyres.
But then you dont seem to keep any car long enough to find this out!
So why are you persistantly giving out bad advice?
Do you work in a tyre fitters by any chance?
www.sas.org.uk
www.the-ace.org.uk
