Author Topic: failed MOT  (Read 3078 times)
Offline gazpowells
failed MOT
« on: 24 February 2013, 21:11 »
after some help please
car failed mot friday with high emissions after looking at it today i noticed the previous owner has un-pluuged the lamba sensor would this cause very high emissions?
Garage said the CO and Lamba reading was well over would the sensor un plugged corse this or has my cat gone?
any help or advice appreciated
thanks
Offline itavaltalainen
Re: failed MOT
« Reply #1 on: 24 February 2013, 21:58 »
reason for it being unplugged... my guess it threw a fuse (the one for the fuel pump) which will logically make the engine stop....
with lambda disconnected it would use a default value.... which is chosen to be slightly rich mixture (less damaging than too lean).... probably checked how much a new one of them was and decided to f**k it (or the old one is stuck he couldnt be bothered to get it out.... hate when people do this....
bet it's not the only issue with it...
I would try to replace lambda sensor, go for a decent quality one... then hook it up to vcds and check it works again (check the vagcom/vcds user list in the garage section). then test in garage if cat was damaged.
Offline tweed
Re: failed MOT
« Reply #2 on: 24 February 2013, 22:20 »
I put my cat in a vice then undo the sensor. They are tight and hard to do with it fitted to the car or on the floor.
And your problem is the unplugged sensor
Offline Bellend
Re: failed MOT
« Reply #3 on: 24 February 2013, 22:41 »
Try undoing it first. Undone one on an 8v and one on my 1.6 both with a spanner on the vehicle. Both undid surprisingly easily...
Where all my moneys went.
Offline gazpowells
Re: failed MOT
« Reply #4 on: 25 February 2013, 19:58 »
thanks guys
Took cat off today to get old sensor out and somebody has removed its insides   :sad:
so new cat and sensor ordered today
hope this sorts it  :smiley:
now to fix all the other fails lol
Re: failed MOT
« Reply #5 on: 27 February 2013, 21:06 »
Another trick for undoing Lamba probes is to try with the exhaust warm (but be carefull)
Offline Len
Re: failed MOT
« Reply #6 on: 28 February 2013, 10:38 »
You need good quality spanners to undo the Lambda.
Never had a problem myself.
www.sas.org.uk
www.the-ace.org.uk
Offline GOLF-MK3-GTI
Re: failed MOT
« Reply #7 on: 28 February 2013, 11:17 »
There's an actual tool for the job itself, Its like a socket that's got a cut out on the side for the lambda wires to go through and all you do is turn it with a ratchet. Very Easy  :cool:
http://tools-from-germany.com/en/HAZET/HAZET-4680-2-Lambda-Probe-Socket
« Last Edit: 28 February 2013, 11:18 by GOLF-MK3-GTI »
Offline Len
Re: failed MOT
« Reply #8 on: 28 February 2013, 12:45 »
Fifty Quid! :shocked:
www.sas.org.uk
www.the-ace.org.uk
Re: failed MOT
« Reply #9 on: 28 February 2013, 13:36 »
I'm sure you can find one cheaper, Good Old Ebay hey  :rolleyes:
