Author Topic: Difference Between GTI and Non GTI Suspension.  (Read 4827 times)
Offline DS1991
« on: 20 February 2013, 16:12 »
I've got a 1.8 Driver MK3 and got a set of GTI suspension spare.
I know the GTI suspension is 15mm lower than normal Golf suspension but was wondering if thats lower on the springs or if the shocks are different size/lower.
cheers.
Offline tweed
Re: Difference Between GTI and Non GTI Suspension.
« Reply #1 on: 20 February 2013, 16:55 »
Pretty sure shocks are shorter  :wink:
Offline javalin
« Reply #2 on: 20 February 2013, 17:54 »
GTI is "+" suspension, 1.8 is standard suspension.  Lots of differences, ARB, Wishbones, ball joints, etc.
Look here at the different parts for GTI vs Non GTI -> http://www.vwspares.co.uk/g3suspension.php
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline boneybradley
  • Back in a Mk3...
« Reply #3 on: 20 February 2013, 18:47 »
shockers are the same, it's the springs that make the gti that bit lower
although as said the arms, anti roll bars etc are different too (19mm arb instead of 17mm for example)
« Reply #4 on: 21 February 2013, 00:10 »
Standard GTI shocks are crap and best off in the bin, use the springs with a new set of gas shocks (Boge are a good choice)
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #5 on: 21 February 2013, 09:06 »
+1 ^^^
Gavv8
« Reply #6 on: 21 February 2013, 09:25 »
The standard shocks i took off mine were Boge.
  • Back in a Mk3...
« Reply #7 on: 21 February 2013, 09:37 »
yeah but after market boge are valved differently... the o.e spec was softer!
« Reply #8 on: 21 February 2013, 09:59 »
Boge turbo gas are what you want if you want to retain some comfort and steer away from sea sickness.
Offline Organisys
  • Old and Slow...
« Reply #9 on: 21 February 2013, 13:07 »
One is really high and soft, the other is just high and soft.
 :grin:
