Author Topic: RED EXCLAMATIONMARK  (Read 974 times)
Offline ShauniiBoii
RED EXCLAMATIONMARK
« on: 20 February 2013, 15:00 »
hey guys was out for a drive as could finally get in car. Went to shops after about 20mile drive got back into car started her up let handbrake down and then got a deeeeep noise and a circle pop up with an exclamation mark inside it and the circle was inside brakets.
did i quick google check and found it said brake fluid would be low checked it and its full :\
also seen that brake pads come up as an orange symbol
and hand brake sensor comes up red with just and exclamation mark inside?
all i can put it down to is hand brake sensor altho (according to what ive seen on google) its the wrong symbol as when i took handbrake off i did it quite harshly and slammed it down... OOPS :P
Offline damien010685
Re: RED EXCLAMATIONMARK
« Reply #1 on: 20 February 2013, 16:37 »
Jesus your having no luck are you!!
Offline navmk4gti
« Reply #2 on: 20 February 2013, 19:45 »
I had the same thing mate when it snowed. After A little drive it went. I just put it down to it sitting in ice for 2 days with the handbrake on.  :lipsrsealed:
Has not come back since. The warning symbol points To the brake fluid. Again mine like yours was full.
Get it up on vagcom incase yours throws something up :wink:
Offline ShauniiBoii
« Reply #3 on: 21 February 2013, 10:12 »
yeah i know damien things are breaking faster than i can fix it haha.
ok cheers mate :)
Offline barrym381
« Reply #4 on: 21 February 2013, 10:16 »
ok cheers mate :)
This is normal for a mk4  :wink:
Offline Nino
« Reply #5 on: 21 February 2013, 12:40 »
ok cheers mate :)
+1
Current - MK6 GTi Edition 35
