Author Topic: Solid mounts.. / Gear shift...  (Read 1446 times)
Offline bretttuk
« on: 27 July 2005, 18:01 »
Going to be purchasing some solid engine mounts aswell. Do i only need to buy one ???? or is there more engine mounts ... any help appreciated...
Also, gearshift is sloppy ... 2nd is crunching sometimes , what do i need to bring the box upto speed and back to normal, i read about some sort of reconditioning kit / bush kit ... who and where do i get this from and at how much ??
Thanks again people..
1st week into owning golf and i have already spent £300 - 400 with another load of things to buy aswell... going to be good though once everything is done ...
Offline Mart8V
  • I really should know better by now.....
Re: Solid mounts.. / Gear shift...
« Reply #1 on: 27 July 2005, 18:10 »
Not sure about solid mounts, but try GSF for the linkage kit to improve the shift, and also a weighted shift rod from VAG.  These are made for the Mk 3 but are a perfect fit for Mk2.  Try your local scrappy if you don't want to fork out the £12 for VAG part.  If changing the linkage you will also need the plate that holds the gear lever and rods in place when you put it all back together.  Available on fleabay for about a tenner.
Good luck!
Offline Mr Blue
« Reply #2 on: 27 July 2005, 18:18 »
some only have a solid front engine mount. Been told its not practical for everyday use as you get vibration through the car.
Offline ...joe
« Reply #3 on: 27 July 2005, 18:55 »
i can get you solid engine mount for the front. you only need the front one as its the only one that gets pulled, the others get compressed. i use one and have not noticed any increase in vibrations. pm me if you want more info.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline bretttuk
« Reply #4 on: 27 July 2005, 19:38 »
Have you got any VAG part numbers so i can give em a bell and order straight away tomorrow.
Also, what is the plate you speak of , where can i get and what part no's if any.
Thanks for the help.
« Last Edit: 27 July 2005, 19:41 by bretttuk »
Offline Dizzie
  • Make friends with your fast
« Reply #5 on: 27 July 2005, 20:32 »
solid front will be the best bet like joe said. leave the others as they are just make sure they're in good enough condition to cope. if you can fit the mk3 vr6 ones on the back as these are build to take the heavier 6 pot.
Offline Organisys
  • Old and Slow...
« Reply #6 on: 28 July 2005, 13:16 »
What are the benefits of a solid mount?
Offline ...joe
« Reply #7 on: 28 July 2005, 23:38 »
better transfer of power and no risk of your mounts f**king up in the fututre!!!
