Author Topic: Need help car idleing erratically  (Read 4445 times)
Offline Jazz-blue-Wayne
« on: 17 February 2013, 12:37 »
Hi all can anyone help me with my Issue with my car agu code
I've changed the maf and lambda sensor
And it still dose it next step is to Clean the throtle body
it's been doing it sine I changed the fuel filter?
My car bolf got 267bhp in my agu with a k04 convertion   piper x cold air induction kit, r-tech custom remap, custom down pipe and sports cat, milltek exhaust system, 4bar fpr, injectors off a ford f150 lightning pick
Offline stfc_gti
Re: Need help car idleing erratically
« Reply #1 on: 17 February 2013, 14:29 »
could be a number of things, theres been a few topics started in the last few weeks about this. 1st thing would be to search through the last few pages of this forum section. 2nd would be to scan the car for fault codes.
2002 1.8T GTI AUM, Standard (not for much longer)
« Reply #2 on: 17 February 2013, 14:52 »
There's no odes come up
Offline Bennmk3
« Reply #3 on: 17 February 2013, 16:34 »
Try a new temperature sensor perhaps ? Had the same fault on mine and ive fixed a few with this fault
Ben
Offline novadragon007
  • Love at first clutch bite...
« Reply #4 on: 17 February 2013, 17:10 »
sorry to jump onto this thread but im having the same issue so thought for the price of a temp sensor might aswell do that since ive now done the MAF, Lambda, checked for air leaks, diverter valve and N75 and running out of stuff to do
just to confirm is this the temp sensor i need http://www.ebay.co.uk/itm/GREEN-Water-Temperature-Sensor-VW-Golf-Mk4-1-6-2-0-GTI-coolant-temp-sender-gauge-/400352006946?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5d36d6d322
Cars a 1.8t Mk4 AUM
Mk4 GTi 1.8t 16" BBS Alloys, Coilovers, Full Exhaust, Catch can..... More to come - If i ever beat this 17705
Offline dom
  • Back in a Mk4
« Reply #5 on: 17 February 2013, 17:49 »
Have a look at the one you currently have fitted as there are a few different ones. If you've got one fitted with that shaped plug then it'll be fine.
I wouldn't expect one that cheap to last for very long, but it will give you an indication as to whether the temp sensor is at fault.
Offline stfc_gti
« Reply #6 on: 17 February 2013, 18:15 »
check your exhaust isnt blowing.
Offline Bennmk3
« Reply #7 on: 17 February 2013, 22:31 »
There is 2 temperature sensors on the mk4 , the one you'll need to change is a 4 pin sensor , mine I changed was green
Ben
Cars a 1.8t Mk4 AUM
Offline Bennmk3
« Reply #8 on: 17 February 2013, 22:34 »
Just to confirm that is the correct sensor but your best off getting one from a vw specialist dependant where your based i got a genuine one for £17 with the o-ring and also make sure you've for coolant or save you old and re use
Cars a 1.8t Mk4 AUM
« Reply #9 on: 17 February 2013, 23:03 »
cheers for the info i found a guide on how to do it plus one for the thermostat so gonna do both and ive ordered genuine parts. Figured even if it isnt the temp sensor causing it atleast i wont be replacing it in 2 months cause of a cheap part. should last me quite a while now and can rule it out totally. My exhaust did have a leak but it was patched and didnt help the mpg its possible the patch has popped again but would that cause the erratic idle aswell? and the cutting out?
