Golf mk5
engine cover
Topic: engine cover (Read 1450 times)
mossy1969
GTI forum regular
engine cover
16 February 2013, 12:17 »
hi there just a quick one the engine cover has a rattle and is loose is it easy to take it off to tighten the bolt cheers
bacillus
Re: engine cover
16 February 2013, 18:50 »
You need a bit of a measured tug at the cover as it can be a b*tch to get off. Start at the right rear (when looking at the engine) and pull upwards taking care to hold onto a thick bit of plastic lest you crack the cover.
I suspect one or more of the rubber grommets aren't securely seated into the engine cover.
Without traction power is nothing!
mossy1969
GTI forum regular
Re: engine cover
16 February 2013, 22:08 »
cheers will have a go in morning many thanks
Jimble
Forum addict
Re: engine cover
17 February 2013, 01:18 »
Might be worth trying to push it down first? My mk6 cover comes off dead easy with a little tug but if the TFSI cover is awkward to come off like bacillus says then try pushing it on first.
mossy1969
GTI forum regular
Re: engine cover
18 February 2013, 06:25 »
sorted the problem yesterday one of the pop on brackets at the front was loose and is bolted to the engine ,simply tightened it up and put back together , jobsa gudun
Golf mk5
engine cover
