Author Topic: off for a decat custom what about 2nd o2 sensor advice NOW WITH PICS/VID  (Read 8341 times)
Offline davemk4
bit late to be worrying about this now but im having a custom  3'' downpipe with 3'' decat with flanges wleded to the oem cat and flanges onto the downpipe and jetex system that way i have a plug in/drop out decat/cat set up.
but i have 2 o2 sensors now obv thinking ahead
http://www.awesomegti.com/car/vw/golfmk4/42-draft-designs-o2-sensor-spacer
this would be fine. but untill this arrives.....the engine light im sure will come on with the decat tommorow. this doesnt bother me BUT will this cause car to go into limp mode etc?
« Last Edit: 15 February 2013, 20:54 by davemk4 »
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline DubAndDubber
Re: off for a decat custom what about 2nd o2 sensor advice
« Reply #1 on: 14 February 2013, 20:54 »
A headache is what reading this gave me. *in voice of yoda*
Mk5 Golf Gti 06'
Offline Scott D
« Reply #2 on: 14 February 2013, 21:10 »
think a spacer on the 2nd lambda should prevent engine light coming on, shouldnt go into limp mode even if it does throw up a fault code
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline davemk4
« Reply #3 on: 14 February 2013, 22:26 »
I hope not.
Offline dom
  • Back in a Mk4
« Reply #4 on: 14 February 2013, 22:55 »
I've been running a decat for at least 5k miles and haven't had the engine management light thrown up yet :cool:
Offline crazy golf
« Reply #5 on: 15 February 2013, 00:27 »
probly from the little i know only the agu aint fussy with atmos dump valves and de cats
Offline davemk4
« Reply #6 on: 15 February 2013, 06:38 »
Mines a aum so a sneeze sets the light on lol
Offline GTi_James
« Reply #7 on: 15 February 2013, 08:23 »
+1  :angry:
Offline davemk4
« Reply #8 on: 15 February 2013, 09:16 »
Well we going to struggle getting the oem cat to fit the custom down pipe. So going to fit a drop in drop out free flowing cat.
Offline Metallix
« Reply #9 on: 15 February 2013, 09:31 »
Take a trip to the dyno, test the decat vs. the high flow cat.
Will show you if there is a gain to be had
