Author Topic: Off to Rtech..  (Read 5583 times)
Offline DubAndDubber
Off to Rtech..
« on: 14 February 2013, 17:46 »
Bit the bullet and booked myself in for a remap.
I've raised the car slightly today as I was told to do so..! Anyone had any problems getting onto the rollers?
I can't remember exactly but I'm sure he told me to have 97 Ron or above for when I arrive, anyone have any recommendations for what fuel to use?
Any tips and hints would be great, I'm a little nervous :grin:
Mk5 Golf Gti 06'
Offline Chris#101
Re: Off to Rtech..
« Reply #1 on: 14 February 2013, 18:02 »
Tesco momentum highest Ron you can buy 99 :wink:
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline damien010685
Re: Off to Rtech..
« Reply #2 on: 14 February 2013, 18:14 »
Or v power which is also 99 Ron
« Last Edit: 14 February 2013, 18:17 by damien010685 »
Re: Off to Rtech..
« Reply #3 on: 14 February 2013, 18:55 »
Anyone know how much fuel they actually use doing the remap?
Mk5 Golf Gti 06'
Offline Khare
  • The bear that khares
Re: Off to Rtech..
« Reply #4 on: 14 February 2013, 18:58 »
I'd use Vpower. I used to use Momentum 99 until the moment I found out the way tesco get the 99 rating....With ethanol....They use normal fuel, add ethanol and get 99RON.
Shell make Vpower separately from it's normal fuels, it's a true 99RON fuel. Since switching to Vpower I've noticed smoother running and better response. Only downside is it's a little bit more expensive.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Off to Rtech..
« Reply #5 on: 14 February 2013, 19:17 »
I can't afford a trip over to Portsmouth every time I need fuel though lol
Offline Bellend
Re: Off to Rtech..
« Reply #6 on: 14 February 2013, 19:48 »
V Power makes single handedly the mos difference in the SDI. Any increase at all is nice but really does make a difference, on hills where 60 might of been possible, it will surge up to 85MPH.
Literally unbelievable the difference it makes. I have a feeling something in it has cleaned out the fuel system as it runs so much quieter.
Where all my moneys went.
Re: Off to Rtech..
« Reply #7 on: 14 February 2013, 19:50 »
I don't know why but that sounded so sarcastic!
Mk5 Golf Gti 06'
Offline AD1.8T
Re: Off to Rtech..
« Reply #8 on: 14 February 2013, 19:51 »
Theres no shell garages on the i-o-w madness!  :laugh:
Offline Bellend
Re: Off to Rtech..
« Reply #9 on: 14 February 2013, 19:54 »
It's not for once. :grin:
I did wonder why the SDI was quite as slow as it was and it genuinely seems to have improved things. I have to hold my hands up and say I've never researched fuels and don't really understand how they make higher RON stuff but I wonder if it has, as I said helped clean the fuel system out.
Put half a tank in as there was nothing else in the place and really noticed a difference by quarter of a tank.
