Author Topic: What oil filter do I need?  (Read 3698 times)
Offline Godzilla
  • <<<VR6 MADNESS>>>
« on: 13 February 2013, 21:37 »
Thought I would change the oil for peace of mind even though last owner said it was done recently.
Thing is my engine is out of an Audi TT......How do I know what filter to get as they did a few, the 150, 180 and 225.
Offline itavaltalainen
Re: What oil filter do I need?
« Reply #1 on: 13 February 2013, 21:49 »
whats the engine code?
steel can or filter insert?
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #2 on: 13 February 2013, 22:03 »
It is a steel can mate.......Just going to check engine code......
Im back!!  It is....BUR
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #3 on: 13 February 2013, 22:07 »
yours is not the 225 engine
its the 150 / 180 version you would need, but if its now running a K04, im guessing it will be running the TIP from a S3, and a S3 MAF, in that case it will need a S3 filter like mine, iv got a K&N 57I
Not no ordinary GTI....
www.mixcloud.com/kells/
« Reply #4 on: 13 February 2013, 22:08 »
I would run a standard genuine one.
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #5 on: 13 February 2013, 22:43 »
Just looked through some of the Dyno's.  First Dyno says 153bhp as standard then 210.8bhp after map so indeed it must be the 150bhp version I have. The next Dyno sheet is very blurry and reads 279bhp but does not have the car reg beside it, almost like it has been copied?
The is a VW/Audi parts place just a few miles from me. So I need to ask for a BUR engine code 150bhp oil filter?
« Reply #6 on: 13 February 2013, 23:53 »
Yep but from memory they are all the same.
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #7 on: 14 February 2013, 16:24 »
Interesting.....  I called VW/Audi parts and they say the engine code BUR does not exist and the part number on the oil filter cant be seen due to the length of time it has been on there  :undecided:
Offline Screech16v
  • MK3 20vt AGU
« Reply #8 on: 14 February 2013, 17:19 »
I read bvr on the advert  :whistle:
« Reply #9 on: 14 February 2013, 18:00 »
You need a MANN W 719/30 or Bosch 0 451 103 314 or equivalent.
