Author Topic: What oil filter do I need?  (Read 3699 times)
Offline Godzilla
  • <<<VR6 MADNESS>>>
Re: What oil filter do I need?
« Reply #10 on: 14 February 2013, 19:28 »
I read bvr on the advert  :whistle:
Of course bud, just testing that you read it correctly.........I am going to go and hide now  :whistle:
On a serious note.....Thank you......It looks like BUR on the block. Time for a visit to Specsavers!
Offline Screech16v
  • MK3 20vt AGU
« Reply #11 on: 14 February 2013, 19:30 »
 :laugh:
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #12 on: 14 February 2013, 22:15 »
just realised you said oil filter and not AIR filter ha
All 1.8T (and may other VWs and Audis) use the smae oil filter, so just get one for any 1.8T
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #13 on: 14 February 2013, 22:39 »
Legend.....Thanks mate  :wink:
Also going to buy some spark plugs as thought I might as well.  I think I will stick to the ones VW use instead of say Bosch Super 4s.
« Reply #14 on: 15 February 2013, 00:42 »
NGK's are the better choice and is what I used after asking in the mk4 section.
Offline F17BAD
« Reply #15 on: 15 February 2013, 14:16 »
Ngk BKR7E is what I use, it's a colder plug than the normal S3 one and better for high output and mapped cars
About 2£ each copper,
Go for copper it's better for conductivity but will need changing every 5k miles or so
Standard ones are NGK PFR6Q
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #16 on: 15 February 2013, 17:59 »
Just ordered some off Ebay mate, thank you for that info  :smiley:
Took my car to VW earlier. Parts guy had a look and said 'Cant see the oil filter part number so cant help'  How useful was that!  He said there are many different ones?  Mine is a can type, not an insert one.
Offline F17BAD
« Reply #17 on: 15 February 2013, 18:31 »
whats the engne code mate?
they are all same for 1.8T
ill get you part number, give me your engine code
Offline itavaltalainen
« Reply #18 on: 15 February 2013, 19:15 »
You need a MANN W 719/30 or Bosch 0 451 103 314 or equivalent.
Offline Lurky
« Reply #19 on: 16 February 2013, 16:56 »
Or just ask them for a OC264 (Mahle) that should cross over in there system if the others dont
