Author Topic: Gauge fitting problems/questions  (Read 1591 times)
Offline cooki
  • 1.8T AUM
« on: 13 February 2013, 13:45 »
Hey guys.
Still havnt got round to fitting my boost gauge and voltmeter gauge yet. Just attempted it but hit a few snags.
1st question is where have you guys rooted the boost hose through. I can't find a gromit on the firewall answer and don't really want to have to take the scuttle panel off.
2nd question do u connect the volt meter wires directly on to the battery?and if so do I need to inline fuse the positive wire at all.
Cheers in advance hopefully lol.
1.8T AUM,18"s,full koni suspension kit,forge split r on fully recirc,k&n induction with cold air feed,FMIC,r32 front,colour coded rear valance,black front and rear VW badges,5 door wind deflectors,boost gauge an volt metre in A pilla pod,full brushed alluminum net optic interior,full creame heated interior,
PLANS: catback exhaust&remapp her  :) :) :)
jockgti
Re: Gauge fitting problems/questions
« Reply #1 on: 14 February 2013, 09:41 »
Don't need to take scuttle off get a metal coathanger and just move scuttle a little and poke through where the bonnet release comes through ,tape pipe to coathanger job done
Offline Screech16v
  • MK3 20vt AGU
« Reply #2 on: 14 February 2013, 09:55 »
You may risk rain water entering the cab if you do it like this ^^^ without sealing it.
Offline cooki
  • 1.8T AUM
« Reply #3 on: 14 February 2013, 11:41 »
I did spot the bonnet cable and think of putting it throught there but as u say it will need sealing afterwards.
Whats involved in taki g the scuttle off. Do u need to remove the wiper arms on mk4??
Any body else got any info on routing the boost pipe??
Also need the volt metre gauge question answering if possible guys cheers :)
jockgti
« Reply #4 on: 14 February 2013, 19:10 »
bit of bathroom sealant in mine worked fine
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 14 February 2013, 20:51 »
Run it down the inside of the wing/door and pop it through the grommet there
Offline cooki
  • 1.8T AUM
« Reply #6 on: 15 February 2013, 00:45 »
Door grommit sounds good. Nice idea.
Volt meter anyone??
Offline Jonnybbad
« Reply #7 on: 15 February 2013, 13:44 »
If you take the glovebox out there's a grommet just behind there which leads out to the left of the scuttle panel. I did the bonnet cable way and ended up filling the csr with water every time it rained
« Reply #8 on: 15 February 2013, 13:55 »
I used the bonnet cable grommet and it leaked, ended up drilling a hole in the bulkhead.
Offline cullygti
« Reply #9 on: 15 February 2013, 13:55 »
theres a gromet behind the carpet in the passenger footwell take a look at my build thread much easier than any other location imo  :smiley:
