Author Topic: Connecting iphone to built in bluetooth phone system  (Read 2250 times)
Offline Steezy
« on: 13 February 2013, 13:35 »
Hi all
I'm new to this forum so apologies if you've already answered this but I can't find the answer anywhere.
I recently bough a second hand 2008 golf 2.0 tdi gt sport and I can't work out how to set up my phone with the bluetooth connection (it has the built in satnav, media, radio, etc touch screen bit in the car).
I wonder if anyone has a step by step guide on how to link the phone with the telephone bluetooth?
Thanks
Offline Rhyso
Re: Connecting iphone to built in bluetooth phone system
« Reply #1 on: 13 February 2013, 13:54 »
Welcome  :smiley:
Are you 100% sure its fitted with bluetooth?  :undecided:  Sounds daft but the previous owner may not have specced the bluetooth.  Just because its fitted with satnav doesn't automatically mean its got the bluetooth module fitted; they were separate options.  It could be the previous owner has retro-fitted the satnav as its a popular upgrade  :smiley:
Turn the ignition on
Go to Setting > Bluetooth . search devices
If found it should appear and then ask you to pair; think the code is 1234 or something like that.  Also if you have several devices paired with your iPhone, delete them all so that the phone has a good chance of pairing with the module (if fitted)
Hope that helps
Offline Steezy
« Reply #2 on: 13 February 2013, 14:11 »
Thanks.
I tried searching for devices last night and the phone found the car through bluetooth but it didn't ask me for anything else (i.e. didn't ask for a code) and then I couldn't figure out how to use the phone through the car.
I'm guessing if the phone found the car's bluetooth, then the car must have bluetooth...
Is there anything I need to do with the car (other than having the ignition on) to connect the two?
Thanks for your help.
Offline Rhyso
« Reply #3 on: 13 February 2013, 14:42 »
When it appears on the iPhone click on the device name and it should ask you to connect / pair?  You then enter the code and go from there  :smiley:
