Author Topic: Is it possible to upgrade brakes without bigger discs?  (Read 1171 times)
Offline mailatstevegilesdotnet
« on: 12 February 2013, 21:53 »
Pretty much as the title says actually - will be due a new set of front discs and pads come MOT time in June and would like to improve braking performance without fitting bigger discs. Is it feasible/sensible/cost effective to get a set of drilled discs and performance pads fitted or is this just going to cost more and achieve nothing?
Thanks,
Golf Mk IV GTi
Offline Toby
  • Car - less
Re: Is it possible to upgrade brakes without bigger discs?
« Reply #1 on: 12 February 2013, 22:02 »
Pads I guess!
312mm upgrade will save you calipers but you need carriers disks and pads
Currently down under
Offline mar_k
« Reply #2 on: 12 February 2013, 22:03 »
How old is your brake fluid?
If its ageing simple fluid change would give you much better braking performance than you realise,
Offline dom
  • Back in a Mk4
« Reply #3 on: 12 February 2013, 22:13 »
Just make sure you buy a decent brand, I wouldn't bother with drilled & grooved for road use.
Offline Golf_GT_TDI
  • 2015 (65) Golf GTD, 2016 (66) Golf GTI
« Reply #4 on: 12 February 2013, 23:15 »
I fitted genuine VW discs and pads all round then had brake fluid changed, it made quite a difference!
« Reply #5 on: 12 February 2013, 23:58 »
^^This, they tend to crack really easy as well.
Offline rockmonkey69
« Reply #6 on: 13 February 2013, 00:06 »
Thanks,
Golf Mk IV GTi
I agree with what everyone has said, they are good folks and you won't go wrong with their advise.
« Reply #7 on: 13 February 2013, 21:12 »
OK, thanks everyone.
 :smiley:
