Author Topic: boost levels ?  (Read 2139 times)
Offline matty james
boost levels ?
« on: 12 February 2013, 20:41 »
can anyone tell me the top boost psi should be on a standard 2002 18t 180bhp engine is please, thankyou in advance  :smiley:
mk3 gti"s and vr6"s,present a silver mk4 anniversary on adjustable coilovers.
Offline Chris#101
Re: boost levels ?
« Reply #1 on: 12 February 2013, 21:10 »
Around 12.5psi bud  :smiley:
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline matty james
Re: boost levels ?
« Reply #2 on: 12 February 2013, 21:20 »
right think im getting bit more than that<will check exactly how much 2mora, was wonderin because ive had car for 2ish months now and it is extremmely fast and wid all forge stuff on it im thinking its had a remap, got into a bit of a race wid a cupra on saturday and i left it, my pals driven it and  and says its fast, my 1st turbo so a bit of a newbie on em. it was drivin rubbish till i got a new maf on a couple of weeks ago and its a different car now.
Offline Chris#101
Re: boost levels ?
« Reply #3 on: 12 February 2013, 21:30 »
More than likely been remapped  :smiley: let us know about boost readings
Offline matty james
Re: boost levels ?
« Reply #4 on: 12 February 2013, 21:36 »
if it has been remapped does it needa different maf, or just a {working} standard one ? maybe showin my inexperience now lol  :smiley:
Offline dom
  • Back in a Mk4
Re: boost levels ?
« Reply #5 on: 12 February 2013, 22:14 »
Just a map won't require a bigger maf...is there any reason you think that your maf is faulty?
Re: boost levels ?
« Reply #6 on: 13 February 2013, 00:00 »
I think it is less than that, my Octavia vRS was a max of 8psi standard and around 14/16psi mapped.
Offline Dalo Harkin
Re: boost levels ?
« Reply #7 on: 13 February 2013, 07:22 »
My stage 2 peaks at 22/23 psi  :wink:
Offline matty james
Re: boost levels ?
« Reply #8 on: 13 February 2013, 13:54 »
took it out today and gauge needle is hitting around 23psi, this car must have had a remap or something,plus with all the forge stuff on it it has to have been. had the car since november, its my1st turbo so on a steep learning curve lol im getting around 33 to 38mpg on journeys 25mile or longer if i drive it sensibly, does this sound right to any of you ? only asking bout the maf because when i bought it it soon became apparent that i needed a new one,since fitted 23psi is what ive been getting, thought u maybe needed a upgraded maf if u had a remap thats all. does 23 sound alot? and if not woould i still be getting the mpg im getting with that sort of boost ?  on the over hand could the boost gauge be faulty ? any advice greatly appreciated  :smiley:
Offline asboGTI
Re: boost levels ?
« Reply #9 on: 13 February 2013, 14:49 »
it depends on what stage remap you have had or weather or not its a full custom remap as the previous coment to your says:
so it is possible your stage 2
vw golf mk4 ARZ 1.8T pipercross panel filter, xenon headlights, JOMS coilovers, forge 007p with green spring, audi tt anti roll bar, 3inch ebay trubo back exhaust, COOKIES MONSTER STICKER(adds bhp I swear)
