Author Topic: gt tdi won't start  (Read 5622 times)
Offline Agreeable Slick
  • Unit
Re: gt tdi won't start
« Reply #10 on: 10 February 2013, 18:03 »
if the key has lost its coding, the immobiliser light will stay on and the display a message saying immob. active or something similar
Not the key. ECU as it was completely powerless. Not sure if ECU immo code is hard coded or not.
Offline bridgeking
« Reply #11 on: 10 February 2013, 18:10 »
i have all lights on as normal and go uot as normal when turn key ,there is no light on and no message
golf is a 115 gt tdi 98
Offline bridgeking
« Reply #12 on: 10 February 2013, 18:17 »
x
« Last Edit: 10 February 2013, 18:22 by bridgeking »
Offline bridgeking
« Reply #13 on: 10 February 2013, 18:20 »
the glow plug light comes on and goes out as normal ,there is no light on or message for immobiliers ,its a 98 golf gt tdi 110
Offline bridgeking
« Reply #14 on: 10 February 2013, 18:21 »
do the glow plug light come on with the ignition? if not it might be relay 109, which is behind the removal panel to the right and down of the steering wheel
are there any unusual lights lit up on the cluster?
also is it a pd or non pd version?
it comes on and goes out as normal
Offline EsSeX dAn
« Reply #15 on: 10 February 2013, 20:15 »
right, ok. open the bonnet, when you put tge ignition on can you hear a click coming from the fuel pump? if yes thats normal, its the fuel cut valve opening. if not theres a problem there.
take out the glow plugs and turn it over to see if it squirts diesel out the glow plug holes. if yes itll be something else.
your best to get it fault code read to see if theres anything electrical gone wild.
my 110 went nuts a few months ago, turns out the timing belt tensioner puked up and lost the tension on the fuel pump, so it was getting the fuel, just at the wrong time!
i think i love you.....
