Author Topic: gt tdi won't start  (Read 5610 times)
Offline bridgeking
gt tdi won't start
« on: 10 February 2013, 16:26 »
hi guy , left lights on for couple of hours went to start and tryed to start but just not enough power so took battery off fully charged it put it back on , all lights on dash came on as normal then went out as normal turned key and NOTHING , i've tryed a couple of things: IE 2 more batterys one being a friends off his car that was running (it was a pug tdi ) before and after but still didnt start mine golf : checked all fuses : tryed to bump start it NO  :embarrassed:
There are no clicking nose or any
            CAN ANY ONE HELP ME SORT PLEASE
                     COM'ON YOU GOLF BRAIN BOXES
Offline Anthony
Re: gt tdi won't start
« Reply #1 on: 10 February 2013, 16:39 »
Have you checked the wire to the starter motor ? it comes straight from the battery i think
2003 GT Tdi 150
Offline bridgeking
« Reply #2 on: 10 February 2013, 16:45 »
Yes checked that , and would of still bump started with that any way thanks tho :(
Offline Rhyso
« Reply #3 on: 10 February 2013, 16:46 »
Fuel pump relay?  :undecided:
Offline bridgeking
« Reply #4 on: 10 February 2013, 17:07 »
No ....! but when bump starting it was puffing out small amounts of diesel smoke ......so figured is was ? what amy i looking for to check fuel pump relay please ..?
Offline Rhyso
« Reply #5 on: 10 February 2013, 17:09 »
Think its located under the steering wheel; not 100% sure sadly
Offline bridgeking
« Reply #6 on: 10 February 2013, 17:44 »
how will i know if its gone .......!!
Offline EsSeX dAn
« Reply #7 on: 10 February 2013, 17:48 »
do the glow plug light come on with the ignition? if not it might be relay 109, which is behind the removal panel to the right and down of the steering wheel
are there any unusual lights lit up on the cluster?
also is it a pd or non pd version?
i think i love you.....
Offline Agreeable Slick
  • Unit
« Reply #8 on: 10 February 2013, 17:51 »
Removing the battery with no residual power to keep immobiliser codes in system could mean that the ECU no longer recognises the Key.
That would require an auto-electrician with VAG-TACHO to come out and recode it :sad:
Offline EsSeX dAn
« Reply #9 on: 10 February 2013, 17:54 »
if the key has lost its coding, the immobiliser light will stay on and the display a message saying immob. active or something similar
