Author Topic: mk3 turbo conversion wiring questions  (Read 3165 times)
Offline kelaroost
« on: 09 February 2013, 19:37 »
hi all, new on here
i've had a mk4 a while now and i've just bought a mk3 gti to transplant the running gear into, i also want to fit the dash and clocks from the mk4 into the mk3 so instead of using a modified engine loom and modifying the dash loom is it possible to transplant the whole loom from the 4 into the 3?
if i do this will i still have to get the ecu immobilizer removed or will it all work fine?
will i have to change any plugs over to use existing mk3 components like the lights, wiper motors etc
edit: donor car is a 1999 agu
« Last Edit: 09 February 2013, 19:40 by kelaroost »
Offline danmusic24
Offline benvictors
  • bgk Tuning - coming soon!!!
Re: mk3 turbo conversion wiring questions
« Reply #2 on: 10 February 2013, 08:54 »
^^ That thread answers none of his questions really.
Transplanting the whold thing is a hell of a job, but do-able all the same, some welding/grinding/drilling/cutting and fabricating is required to get the 4 dash to physically fit in the 3. Getting the engine to run is relatively easy doing it this way since yr nott chopping into engine looms etc and you are using the existing keys, ecu and clocks. You need to get yr hands on both full wiring diagrams to wire in the doors, boot, light and fuel system, many wire colours are matched between the 3 and 4 but obviously some arent.
Will take a lot of patience, head scratching, shouting, swearing and probably a few tears but i think it will be worth it, have considered a dash swap in mine a few times and it may still happen.
If you do it, take loads of pics  :wink:
Offline jamiefin
« Reply #3 on: 10 February 2013, 21:43 »
my mk3 turbo runs with the loom of a s3 but uses the original dash and everything works as it should original imobiliser was bypassed and after market on installed I now use two keys the original one now only opens the door while the other one starts the car company called dubshack in the midlands did it give them a shout they will be able to help you out
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #4 on: 10 February 2013, 21:57 »
too much hassle
my S3 engine is on Audi looms and ECU too
but in this case, if he wants to use a mk4 dash, you can buy looms from kufec to do this
just install the engine and splice the wiring into the mk3 fuse box
to re wire the whole car with mk4 stuff would take forever and your doing stuff you dont need to do
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline F17BAD
« Reply #5 on: 10 February 2013, 22:01 »
seen your car in forsale section, thats not a S3 engine as the TB is on wrong side, so i doubt yours has a S3 loom but i agree, this is the best way to wire it in
Offline tweed
« Reply #6 on: 10 February 2013, 22:04 »
Sorry for hi jack but is the AC part of engine loom?
Basically I have a AC gti and non AC vr6 donor. I want to run the AC on the vr and just want a easy job. Electrics do me in  :grin:
Offline jamiefin
« Reply #7 on: 10 February 2013, 22:11 »
yeah its out of a tt roadster
Offline benvictors
« Reply #8 on: 10 February 2013, 22:14 »
Pretty sure the a/c runs on the car loom along with the alternator and the fan/thermostat plugs  :wink:
Offline tweed
« Reply #9 on: 10 February 2013, 22:18 »
Cheers man. Hopefully ill do it this year  :laugh:
